Vibrating Table Saw
Forum topic by JonK posted 01-06-2013 12:49 AM 1754 views 0 times favorited 15 replies Add to Favorites Watch
View JonK's profile
JonK
52 posts in 1887 days
01-06-2013 12:49 AM
Ok guys, I just retro fitted my table saw with the Delta T2 now, the saw unsafely vibrates…any tips to remedy this problem?
15 replies so far
View RonInOhio's profile
RonInOhio
721 posts in 2772 days
#1 posted 01-06-2013 12:54 AM
Whats a Delta T2 ? And since you used the word retro fit, I assume you think you did something in this process to cause this. What modifications did you make that may have caused this ?
View Grandpa's profile
Grandpa
3259 posts in 2583 days
#2 posted 01-06-2013 12:55 AM
Sounds like another problem and not the fence causing this. I don’t know why changing the fence would make one viberate. Belt? Blade? Sheave? bearing?
View JonK's profile
JonK
#3 posted 01-06-2013 01:05 AM
Grandpa, just placed a new blade on it. So, I guess I need to look at the belt. GP, what’s the belt that looks like it’s weaved?
Grandpa
#4 posted 01-06-2013 01:11 AM
Are you talking about a link belt. That should make it run smoother if you have one of those. Take the blade off and see what it does. Change to a different blade. The arbor didn’t get bent did it. It would be worse after you added the blade. I hope not.
View RibsBrisket4me's profile
RibsBrisket4me
1555 posts in 2413 days
#5 posted 01-06-2013 01:17 AM
When my saw vibrates it’s always been one of my belt pulleys coming loose. Quick turn of the allen wrench takes care of it.
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#6 posted 01-06-2013 03:31 AM
Take the blade off and run it to eliminate the blade as the source of the vibration. Stil vibrating? Check the drive pully. Hopefully you’ll solve this before getting to the arbor bearings. I can’t imagine the fence having anything to do with the vibration. I suspect the blade or some crud between the blade and the arbor bushing causing it to wobble.
View History's profile
History
399 posts in 1889 days
#7 posted 01-06-2013 03:42 AM
I had a friend that had a Powermatic Contractor’s saw that had a vibration that it didn’t have before. In the owners manual under trouble shooting and saw vibration they recommended checking that the hand wheel for the blade tilt is locked.
View pintodeluxe's profile
pintodeluxe
5568 posts in 2721 days
#8 posted 01-06-2013 04:06 AM
Some good input and answers here. My TS is on a mobile base. If it gets moved to a dip in the concrete floor, it will wobble a bit. A shim under the leg or mobile base will fix that sort of a problem.
View Rick_M's profile
Rick_M
11133 posts in 2288 days
#9 posted 01-06-2013 05:46 AM
If this mystery saw has a motor hanging off the back, check the belt at the pulley underneath the table.
-- http://thewoodknack.blogspot.com/
View JonK's profile
JonK
#10 posted 01-06-2013 08:22 PM
Thanks everyone.
My next question is about the same problem so, I would like to stay away from the stamped aluminum pulleys; does anyone know where to get a machined 2 1/2 by 5/8 bore v pulley?
View Joe Andrews's profile
Joe Andrews
66 posts in 1907 days
#11 posted 01-06-2013 08:50 PM
History
#12 posted 01-06-2013 09:23 PM
You should be able to find machined pulleys locally at some hardware stores, or a place that sells electric motors.
Grandpa
#13 posted 01-06-2013 09:35 PM
We have a store that sells belt sheaves, sprockets & hydraulic hoses and fittings. If you find one locally great. if you don’t let me know.
View JonK's profile
JonK
#14 posted 01-07-2013 03:06 AM
Grandpa, what do you have for my older craftsman? I’m thinking about starting with solving my problem with the pulleys and belt.
Grandpa
#15 posted 01-07-2013 03:35 AM
I can get the pulleys locally. if you can’t. I would give you the phone number so you could call Harry Brown’s store and place an order. They have good machine pulleys and good belts if you want to use a stand type belt. If you want a link belt I read on here thet the best place to get them is Harbor Freight. Nevery used one myself. I have changed pulleys though.
