Delta electric motor not running up to speed
Forum topic by DouginVa posted 01-05-2013 11:26 PM 3239 views 0 times favorited 22 replies Add to Favorites Watch
View DouginVa's profile
DouginVa
490 posts in 2357 days
01-05-2013 11:26 PM
Topic tags/keywords: jointer question
I just bought a Delta 37-190 6” jointer off of Craigslist. The previous owner didn’t use it much at all and it had been in storage for a very long time when he decided to sell it. There is a lot of surface rust, etc., but nothing a little elbow grease won’t take care of. The problem is with the motor. While it does turn on it runs very slow and eventually trips the circuit and shuts down.
I’m not an electrician and have very little knowledge and/or experience in trouble shooting electric motors. So…..anybody with experience out there that may be able to identify my problem here and ideas on how to fix it?
-- Just a man with his chisel.........
22 replies so far
View BurtC's profile
BurtC
103 posts in 3214 days
#1 posted 01-05-2013 11:34 PM
Sounds like the centrifugal switch is not working right. It is a switch that allows current to the starting windings until up to speed, then only the running windings are active. I think in you case the switch is stuck open. Suggest opening motor and cleaning the switch mechanics and the contacts. Hopefully the windings aren’t burnt. Do you smell a kinda smoke/toxic near motor?
DouginVa
#2 posted 01-05-2013 11:51 PM
No burning odors or unusual noises coming from the motor. The motor hasn’t run long enough yet to overheat anything.
View bbc557ci's profile
bbc557ci
595 posts in 2158 days
#3 posted 01-05-2013 11:59 PM
I had a similar problem with an older Atlas TS I was bringing back up to snuff. A very informative and helpful gent from another site tried to walk me through the process to figure out the problem. But I too am electrically challanged. So, after pricing new 1 hp motors and realizing how much a good / new motor costs, I put a “I’m looking for” add up on Craigslist, and was fortunate enough to get a 1 hp motor for $40.00. Looked almost new and the old Atlas is ripping wood once again :o)
-- Bill, central NY...no where near the "big apple"
View Grandpa's profile
Grandpa
3260 posts in 2759 days
#4 posted 01-06-2013 01:04 AM
This centrifical swith Burt is referring to is often just inside the motor cap opposite the shaft end of the motor. Unplug the motor, take the bolts out and see if you can gently get the end off. There should be some weights and contacts there. If the motor is not totally enclosed it might have wood chips or sawdust in a contact. Clean everything out and reassemble. Sometimes the grease hardens in the bearings. Try turning the bearings while you are there. I have had motors sit for years and not just jump into action when I turned them on. If I can get them started I let them run for awhile. 30 minutes or so. This helps soften things up.
I don’t think that will be a 220V motor but you might look at it and see what the data plate says. Never know what some other guy might have done. Checking the end on the cord won’t help because you don’t what some other guy might have done.
DouginVa
#5 posted 01-06-2013 01:10 AM
I just got the machine from my car and in to my shop. And…..the motor purrs like a kitten. The guy selling it must not have a good flow of electricity to the outlet he used or something…...oh well, his loss my gain. I’ve got an upgraded jointer now for only $50 and some elbow grease work ahead of me.
I’ll have to create a blog on the restoration/refurbishing of this when I get started.
Thanks for the responses guys!
View Dusty56's profile
Dusty56
11819 posts in 3772 days
#6 posted 01-06-2013 01:11 AM
Does it spin easily by hand ?
I’ve had them chuck full of sawdust as well as the grease turned to stone from sitting around for years.
If the motor does turn easily , then I would trouble shoot the electrical side of it as suggested above : )
Grandpa
#7 posted 01-06-2013 01:13 AM
moving it might have dislodged some dust or other debris inside the motor. Check it out like Dusty suggested. Congratulations!!
TopamaxSurvivor
18337 posts in 3760 days
#8 posted 01-06-2013 01:13 AM
Moving it probably fixed the stuck switch. Whack the end of the motor with a mallet if it happens again.
View Tennessee's profile
Tennessee
2876 posts in 2598 days
#9 posted 01-06-2013 01:17 AM
I’d guess that in the trip, you might have broken loose some debris that was keeping the switch from operating correctly. Burt is right, the start switch was staying open. If it was a capacitor, it would not have turned at all.
You broke loose the switch on the trip.
DouginVa
#10 posted 01-06-2013 01:18 AM
@ Dusty; yes it did move freely by hand which is why I suspected electrical/motor problems. I’ll be sure to open the motor case up and at a minimum blow some air through there and look for issues.
I’m still grinnin’ as I got a steal on this baby.
Dusty56
#11 posted 01-06-2013 01:22 AM
What kind of a steal ? Did they pay you to take it ? LOL
View DIYaholic's profile
DIYaholic
19634 posts in 2759 days
#12 posted 01-06-2013 01:24 AM
Congrats on the score and motor problem resolution.
You know what they say about pictures….....
DouginVa
#13 posted 01-06-2013 01:26 AM
He was asking $100, I got it for $50. I suspect he was someone who wanted to get in to woodworking, bought a few tools, then lost interest. The knives didn’t even look like they have dulled at all. But at the same time he didn’t protect it from moisture while it was in storage.
Dusty56
#14 posted 01-06-2013 01:42 AM
Ya done good , Doug : ) Rust is an easy fix and a great way to talk down the seller !
View toolie's profile
toolie
2138 posts in 2713 days
#15 posted 01-06-2013 10:30 PM
congrats on a gloatable buy. $50 for a 6” jointer is a gloatable deal in my neck of the woods. but no pics, didn’t happen. so where’s a pic or two of this really good deal?
