I would like to build a stroke sander for my shop. I have a stroke sander drive that can be raised and lowered and has a mounting brackett for the motor and a idler pulley to tighten the belt. This came to me on a pallet of junk that I bought at a auction, I was after some good bench vices that were in the same lot and didn't find the drive untill I got home. I have no idea what the hp requirments are for these I will proably build one a little on the small side for doing cabinet doors. As I will need to make a pulley for the other end I am interested in what others have used for bearings and shafts , it seems like glued up pcs. of mdf or baltic birch would make a good pulley. also interested in how others have built the table slides and hight adjustment.
I have the end pulleys assemblies. The part that drives the sanding belt. Is that the part you already have? Mine has a double pulley, so I'm guessing that you'll need at least a 3hp motor to drive it. This is another one of those things that I found the parts for, put never had time to work on. If these sound like parts that you may need for yours let me know. Fine Woodworking, Volume 1, issue 3 had a nice article on building a stroke sander.
I have the drive end including a 9 inch diameter pulley that the sanding belt runs on. I do not have the matching one for the other end of the sanding belt but I really don't think it will be to hard to make one for the other end as it will just be the idler. I am thinking I will make it of mdf and machine out pockets to accomidate ball bearings that will run on a 1" steel shaft.
I looked up the article. It's by A.W. Marlowe - I don't have a FWW
index but I reckon it must have been in one of the first 40-50 issues.
If you have the CDs it should be in there.
Can anyone help me with plans for diy stroke sander
Its nice ti have a basic design and as you build you can improve here and there
thanks
msparg10@gmail.com
I read the title of this thread and was slightly amused, I couldn't give one away a few years back. This sander came from a joinery and mainly sanded passage doors. I used it to sand cabinet doors, assembled drawers and small table tops. Everything of value was demounted and wrecker got the rest
Here's the stroke sander I built in 2105. It was taken from AW Marlow's design in FW mag. It works very well. If you're interested I can find the the magazine and give you information. -M
Here s the stroke sander I built in 2105. It was taken from AW Marlow s design in FW mag. It works very well. If you re interested I can find the the magazine and give you information. -M
How is the dust collection for that? What size motor?
I have been seriously thinkiing of getting one for sanding down my stone inlays that I used to fill voids and cracks.
I was thinking the stroke sander would allow me to get the stone down to level faster than multiple passes through the drum sander.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
