problem with DeWalt 788 blower
« back to Scrollsawing forum
Forum topic by JesseTutt posted 133 days ago 559 views 0 times favorited 9 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
707 posts in 276 days
133 days ago
Topic tags/keywords: question scroll saw dewalt dewalt 788
The blower tube that connects to the upper arm and flexes to blow the saw dust off of the wood cracked and now will not stay where I placed it. The first joint where the black plastic connects to the steel ball has a crack in it. The slight vibration when the saw is running causes the entire tube to drop onto the table.
Here is a picture of the saw:
and a close-up of the break:
I tried to remove the last segment but it would not easily come off the tube. I don’t want to try to force it because it might break the next segment. Would you use expoy, hot melt, or ??
I thought about gluing the last segment to the metal connector. That would decrease flexibly (positioning of the blower tube) but at least I would have something.
What do you think?
9 replies so far
View Bill White's profile
Bill White
2601 posts in 2126 days
#1 posted 133 days ago
I gave up on the std. blowers on scrollers. Built my own by using a standard 1/4” air hose connector, some clear tubing and a nozzle fabbed from small brass tubing.
Now I just hook the blower to the compressor at a very low pressure setting.
Works like a champ, and I don’t have to futz around with the crappy blower stuff on my saw.
Just the way I did it.
Bill
-- bill@magraphics.us
View shipwright's profile
shipwright
3372 posts in 964 days
#2 posted 133 days ago
I had the same problem on my DeWalt.
I got a new one on warranty. While I was waiting for it I did get the broken piece to come out without breaking anything….and the “new” socket snapped on to the base ball.
Maybe I was just lucky but try it. You have only one segment to lose.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View me5269's profile
me5269
37 posts in 333 days
#3 posted 133 days ago
i remeber reading somewhere that someone with the same problem used a heat gun or hair dryer to warm up the joint and it popped right apart. also used the same method to attach the new joint to the ball.
Mike
-- Mike
View Grandpa's profile
Grandpa
2380 posts in 841 days
#4 posted 133 days ago
That looks like the same part that metal working machines use for coolant. Check with a place that sells those parts and see what it would cost. This appears to be too short. You might get a better quality from these places if they will attach to your saw. A part for a $5,000 machine should be better than a part for a $500 machine. I don’t know.
View Madwood's profile
Madwood
35 posts in 1217 days
#5 posted 133 days ago
Jesse, try softening the 2nd link with a blow dryer or heat gun. Once it’s a little soft, it’ll pop the 1st link without much effort.While it’s still soft, press it onto the metal nub on the side of the saw. Once it cools down, it should be good as new. On the chance that won’t work for you, another option could be to use a small hose clamp to hold it place and seal any leakage with hotmelt glue. YMMV
John
-- In the shop making chaos out of order
View joein10asee's profile
joein10asee
1659 posts in 173 days
#6 posted 133 days ago
Those links just pop in and out of each other. If you put a bit of pressure and bend the “hose” far enough at any point you’ll see how easy they actually do snap apart. That way you can make ‘em longer or shorter as needed
View gvales's profile
gvales
20 posts in 505 days
#7 posted 126 days ago
Had same problem brand new. Dewalt is replacing under warranty, but for now I just used a small worm drive hose clamp.
View Muddquez's profile
Muddquez
2 posts in 144 days
#8 posted 124 days ago
It looks like 1/4 inch Loc-line, you can get it directly from the company if you want to replace any of it. It should come off without breaking any of the other links though.
loc-line.com
View William's profile
William
7056 posts in 1008 days
#9 posted 124 days ago
My saw hasn’t had a blower on it in a year or two. I just blow dust away with my mouth if enough gets in the way of me seeing what I’m working on.
I do think that’ll snap out though. If not, what have you lost? From what you’re saying, the blower is useless as is anyway. I say use some of the suggestions here and go for it.
