| Forum topic by RussellAP | posted 165 days ago | 409 views | 0 times favorited | 11 replies | ![]() |
165 days ago |
I need to fill this while also putting some red coral on the surface. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
11 replies so far
#1 posted 165 days ago |
Bondo -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 165 days ago |
I would be concerned that Bondo might not be elastic enough to support wood movement. The only place I used Bondo was on a car’s fender back in the 70s. I don’t understand your reference to “red coral on the surface.” Are you talking about something like InLace? -- Jesse, Saint Louis, Missouri |
#3 posted 165 days ago |
Bondo works great I’ve used it on wood for years .The wood movement on a piece that size is minimal. If you don’t feel good about it Russ use some pieces of wood cut to fit and epoxy . -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 165 days ago |
Bondo works good. I used it to repair window sills when I was a remodeling contractor. Once it’s applied and cured, there is not much that is going to make it rot! -- Improvise.... Adapt...... Overcome! |
#5 posted 165 days ago |
Our pattern shop pattern makers have used bondo for years. Works great. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#6 posted 165 days ago |
I’ll have to look at that bondo stuff tomorrow. I hope it’s not runny. Tell me Jim, with all the finishing I still have to do, should I shellac the whole thing as a seal against glue stains. That CA glue darkens the wood. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 165 days ago |
Russ -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#8 posted 165 days ago |
which bondo do you get? Bondo 28 oz Epoxy Drywall Metal and Wood Patching Compound? -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#9 posted 165 days ago |
Bondo is a brand name Russ you will need some spreaders too. Make sure to clean them with lacquer thinner right after your through with them -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 164 days ago |
There is Bondo for metal, which has been around for years, and Bondo for wood, which is a more recent product. It’s kind of a light tan (regular Bondo tends to be reddish brown). Another good patch is epoxy mixed with wood flour or sanding dust. It will take on the color of any stain you use. But if you are going for the natural color of the wood, it will be darker than the base wood when you finish. It’s a very tough patch, able to withstand wood movement. |
#11 posted 164 days ago |
my dad never fixed a car but he loved bondo in woodworking. he used it for jigs and fixtures as well wrapped the part he wanted to support for an operation in cling wrap and then pressed it into the bondo to set. |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
