Lifting things onto the bench?
Forum topic by Don W posted 01-04-2013 09:31 PM 2339 views 0 times favorited 40 replies Add to Favorites Watch
View Don W's profile
Don W
18754 posts in 2593 days
01-04-2013 09:31 PM
As I was working on my thickness sander today, I realized getting it on and off the bench was not easy task. I find as I get older, lifting and bending is not quit as easy as it used to be. I’m not old enough yet that it slows me down, but it does start me thinking.
I found myself standing it on one leg, walking it to the bench, getting one side on and lifting it up. Now, minor scratches on this doesn’t matter, but when your working on a more delicate project, you need to be more careful.
So my question is, how do you deal with this type of situation? Do you just work on it on the floor once its together or What do you do?
40 replies so far
View bhog's profile
bhog
2236 posts in 2715 days
#1 posted 01-04-2013 09:34 PM
A rope and pulley from the rafters will help alot.
-- I don't drive a Prius.
View John's profile
John
341 posts in 3823 days
#2 posted 01-04-2013 09:42 PM
here’s something i’ve considered, but haven’t done yet http://www.harborfreight.com/gambrel-and-pulley-hoist-99758.html
-- John - Central PA - http://affyx.wordpress.com
Don W
#3 posted 01-04-2013 09:46 PM
I haven’t found the ropes and pulleys all that great for woodworking projects. JC, I use something similar to hang my deer, it works well for that.
View RonInOhio's profile
RonInOhio
721 posts in 2889 days
#4 posted 01-04-2013 09:57 PM
Its probably a matter of getting your shop situated for optimum ease of
your work flow. And also acquiring some special material handling helpers.
Every shop is different and we all have our own shop issues and yours dealing with heavy material is probably a common one.
Maybe start thinking about helper carts, special material handling setups, and especially work flow.
For example, is your lumber storage situated in such a way that if facilates the initial handling and milling
without carrying it across the shop ?
For rough cut lumber I would suggest that if possible have it close by to
your machines that you will use first. Perhaps the jointer. And if possible have the sander maybe near the out feed of your jointer . Rollers and out feed tables are helpful too.
They sell heavy material handling carts at Harbor Freight that are hydraulic. The light duty one will lift 500 lbs about belt high or higher if I’m not mistaken. The heavy duty one will lift 1000 lbs.
You could build a mobile horizonal dolly or infeed table long enough to support larger longer pieces about the height of your tools. Just wheel it to the machine and set it up on the infeed. Then use it to transport the piece to the next machine.
There are a lot of material handling ideas out there from breaking down large sheet material to maneuvering large sheets and material around the shop and lifting up to and onto your saws and such.
The overhead hoists set up on some kind of x ,y track would also elimate alot of lifting provided there is room overhead .
Here are those carts I was talking about.
http://www.harborfreight.com/catalogsearch/result?q=Hydraulic+Cart
View Brandon's profile
Brandon
4152 posts in 2976 days
#5 posted 01-04-2013 10:00 PM
You can build a ramp off the side of the workbench. :-)
-- "hold fast to that which is good"
View crank49's profile
crank49
4032 posts in 2996 days
#6 posted 01-04-2013 10:04 PM
I have a little 1/4 ton ratchet chain hoist I got from HF.
This hoist, attached to a chain over the rafter is perfect for lifting heavies.
Got it on sale for about $40 with a coupon. Think it is on sale right now; if not it will be in a couple of months.
Much easier to work with than a cable type com-a-long.
Don W
#7 posted 01-04-2013 10:07 PM
Ron, the question is What do you do?
Work flow is for speed and ease of operation, not heavy lifting.
My lumber storage is typically in my attic. Not ideal, but it is what it is and its not going to change any time soon. Carrying a piece of 2 of lumber is not the issue, and since its a hobby, I’m not usually in any time crunch. Not that I want to waste time, there are just some things that are not going to change.
I like the hydraulic cart idea, but would want to hear of somebody who has used it in their woodworking shop before I even thought about buying one.
Don W
#8 posted 01-04-2013 10:10 PM
Brandon, I’ve used temporary ramps. I’d be tripping over a permanent one.
Michael, how high are your ceilings.
crank49
#9 posted 01-04-2013 10:17 PM
My shop is in the drive-in basement, behind the garage. I built my house with a couple extra rows of blocks so I have a minimum 8’-6” ceiling. That little hoist I referred to is only about 12” hook to hook. It’s made to carry in your tool box, but I use it all the time. I have put a pipe through a couple of holes in two joists and gained an extra 8” or so. Doing it like that I put the ratchet end on the load, at the bottom, and ratchet it up the chain.
Don W
#10 posted 01-04-2013 10:19 PM
thanks, I’ll look into that.
RonInOhio
#11 posted 01-04-2013 10:22 PM
Guess if you don’t you see how efficient work flow and ease of operation equates to not doing as much heavy lifting, then don’t know what to tell you.
What I do is try to make things as simple as I can. I need a 4×8 sheet , i have them cut it down before I bring it home. I haven’t built many larger projects so I only offered up some suggestions.
View Thalweg's profile
Thalweg
97 posts in 3431 days
#12 posted 01-04-2013 10:26 PM
I use a cheap Harbor Frieght shop crane (cherry picker) for really heavy stuff. Ceiling lifting wouldn’t work well in my shop. The problem with a cherry picker is the storage space.
View stefang's profile
stefang
15881 posts in 3359 days
#13 posted 01-04-2013 10:35 PM
i’m so old and decrepit that I forgot! One good trick might be having moving type blankets/pads on hand and some stretch bindings to hold the blanket in place while moving the workpiece. It also sometimes helpful to have one as a nice soft layer under the workpiece on the bench. As for the heaviness issue, a table with a drop leaf top and with wheels could be handy to help moving the pieces around above bending height.
View DaddyZ's profile
DaddyZ
2475 posts in 3066 days
#14 posted 01-04-2013 10:48 PM
Don ^ I feel for ya, Getting Old Just changes the Perspective, Old Timers call it Maturity/Seasoning/Experience…
View Dave's profile
Dave
11429 posts in 2865 days
#15 posted 01-04-2013 10:57 PM
Build this. Put a metal pin in a hole on your bench to where you can take it on and off. You see these things on truck beds.
Get help from the neighbors kids, bribe them with candy
Work out more.
showing 1 through 15 of 40 replies
