Kick back pawl on the rip fence
Forum topic by TopamaxSurvivor posted 140 days ago 468 views 0 times favorited 14 replies Add to Favorites Watch
TopamaxSurvivor
13194 posts in 1848 days
140 days ago
Topic tags/keywords: kick back pawl fence
I have been thinking about putting a pawl on my rip fence as an anti kick back device. Anyone see any issues with this idea?
14 replies so far
runswithscissors
609 posts in 197 days
#1 posted 140 days ago
Interesting idea. I’m trying to picture how you might attach it. Would it be mounted high enough to clear thick material? Easily removable so you can attach auxiliary fences?
TopamaxSurvivor
#2 posted 140 days ago
I am thinking about making something that will clamp on so it is easily removable and reversible. It could clamp on to a bracket on the top of the fence.
Dick, & Barb Cain
8681 posts in 2471 days
#3 posted 140 days ago
Hi
I searched on Google & it showed numerous systems to look at.
View pintodeluxe's profile
pintodeluxe
1756 posts in 985 days
#4 posted 140 days ago
I personally think they get in the way. I focus on sending straight, freshly jointed lumber through the tablesaw to avoid kickbacks. If I were looking for a fence mounted system, I might try Board Buddies which is a set of rubber wheels that only turn one direction. It apparently holds stock down, and prevents kickback.
I have 5 featherboars, but I don’t use them as much as you would think. Ripping S3S stock to width for instance – a featherboard is useless.
Good luck.
View stefang's profile
stefang
9503 posts in 1506 days
#5 posted 140 days ago
Hi Bob. I find a splitter pretty adequate to avoid kick-backs. For every advantage an accessory has there is usually an offsetting disadvantage.
-- Mike, American in Norway
View crank49's profile
crank49
2291 posts in 1143 days
#6 posted 140 days ago
I like the idea of those one way rollers that attach to the fence. They pull the workpiece into the fence and keep it from kicking back at the same time.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View NiteWalker's profile
NiteWalker
1482 posts in 749 days
#7 posted 140 days ago
I also think they get in the way. A well-aligned splitter is the best kick back prevention device IMHO.
TopamaxSurvivor
#8 posted 140 days ago
Michael, Where do you find one way rollers?
Mike, et al, I am thinking it might add another margin if the splitter breaks off the zero clearance plate.
View SASmith               's profile
SASmith
1369 posts in 1159 days
#9 posted 140 days ago
I have not used them but I think this is what Michael was referring to.
I am sure there are different brands and prices. The link was the first one I found with google.
-- Scott Smith, Southern Illinois
View mrg's profile
mrg
483 posts in 1171 days
#10 posted 140 days ago
TopamaxSurvivor,
You can get them at Amazon, Woodcraft, Rockler.
-- mrg
TopamaxSurvivor
#11 posted 140 days ago
Guess I was goggling the wrong term. Nothing like that popped up. Thanks.
crank49
#12 posted 140 days ago
Yeah, that’s the ticket. The ones linked to by SASmith. I have seen them installed and demonstrated at a Woodcraft store and been wanting some every since. They make them with clockwise or counter-clockwise or just free turning for different machines and applications.
View bluekingfisher's profile
bluekingfisher
809 posts in 1151 days
#13 posted 138 days ago
I bought the single rotation and clockwise rotation sets, easy to fit onto a track. The only issue is having to drill and tap your fence to accept the track.
-- No one plans to fail, they just, just fail to plan
View lumberjoe's profile
lumberjoe
2401 posts in 420 days
#14 posted 137 days ago
What about the off cut? The best anti-kickback device i have seen is something my dad made in a machine shop YEARS ago. It Sits over the table slightly behind the blade and as a set of urethane rollers that only spin one way. He made it to attach to the splitter of his specific saw so it won’t attach to mine. It kind of looks like a power feeder.
-- http://www.etsy.com/shop/KandJWoodCrafts
