Which wood for fireplace surround
Forum topic by Dophi posted 01-04-2013 07:07 PM 2254 views 0 times favorited 9 replies Add to Favorites Watch
View Dophi's profile
27 posts in 2760 days
01-04-2013 07:07 PM
I want to build a surround to overlay our current red brick fireplace. We found a design we like. Selecting a material is proving difficult. Most of my research recommends using MDF, primarily for its cost and simplicity to finish. Our surround will be painted, not stained. It seems to me I would not be able to reproduce the design we have chosen using MDF. I considered using poplar. My research indicates there could be an inconsistency in the painted finish. I’ve looked at numerous projects created by members of LJ. I’m confident someone can provide me with the help I need. I am relatively new at woodworking and would appreciate any suggestions on material choice and anything else to do with the project. There is one detail in the picture I will be changing. The rail will have a straight lower edge.
9 replies so far
View shampeon's profile
1775 posts in 2118 days
#1 posted 01-04-2013 07:17 PM
I don’t know why you think poplar would cause an inconsistent finish. Tons of painted wood furniture is made from poplar. Do your prep work correctly, and you should have no problem with poplar.
View GaryL's profile
1099 posts in 2765 days
#2 posted 01-04-2013 07:21 PM
You can use MDF or poplar and get an excellent finish. The work is in the priming. Sand, prime, sand, prime and if need be, repeat. Get as smooth of a primed surface as you need then do your top coats.
I’ve used oils, lacquers, and acrylic latex (top coat) on both and optained excellent results. In my case they were all sprayed.
This is all MDF and poplar.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
#3 posted 01-04-2013 07:31 PM
Could not get a second pic on the first post…..but anyway, this is during the build. Pre-primed the MDF panel edges before assembly to get a head start on the “sealing” prime.
View newwoodbutcher's profile
732 posts in 2785 days
#4 posted 01-04-2013 08:10 PM
Made one with poplar the other with Mahogany
-- Ken
View SCOTSMAN's profile
5849 posts in 3520 days
#5 posted 01-04-2013 08:19 PM
I personally like the Mahagony one best the other is nice too though.It’s just more to my taste have fun. Alistair
View pintodeluxe's profile
5595 posts in 2748 days
#6 posted 01-04-2013 08:32 PM
I dislike working with MDF so much, that I would look at poplar or maple first. Spraying the finish will be key to a top notch project.
View Tennessee's profile
2828 posts in 2449 days
#7 posted 01-04-2013 09:20 PM
I would skip the MDF, personally hate working with it. Poplar for me.
View WDHLT15's profile
1726 posts in 2411 days
#8 posted 01-05-2013 01:40 PM
Poplar or red maple. Get good grade so the knots do not show through.
-- Danny Located in Perry, GA. Forester. Wood-Mizer LT40HD35 Sawmill. Nyle L53 Dehumidification Kiln.
#9 posted 01-08-2013 01:07 PM
Thank you to all for the suggestions and advice. After reading what you have to say, it appears my concern about poplar is overcome if I do the necessary prep work. It was suggested I spray paint. I don’t have the equipment or facilities for the process. Perhaps I will look into sending the finished unit out to be spray painted. Thanks again for everything.
