| Forum topic by dakremer | posted 142 days ago | 1146 views | 0 times favorited | 30 replies | ![]() |
142 days ago |
I dont know why I havent questioned this before – maybe its because its not my saw (I use my bro-in-law’s wood shop), but I always wondered if I could add a riving knife to his Jet saw. It should have been obvious to me, especially since there is an opening in the plate for a riving knife, but it didnt click until I actually saw the flange and bolt/washers for the riving knife (while changing the blade) My question – Do I need to order this from Jet? Is there a cheaper (possibly homemade) alternative? What are my options? I’ve been using his saw for a while now, with one kickback, and would like to bump up my safety precautions, and hopefully make that my last and only kickback. Thanks in advance! -- Hey you dang woodchucks, quit chucking my wood!!!! |
30 replies so far
#1 posted 142 days ago |
Don’t know about the specific saw (do you have model #?), but I know the B.O.R.K. is an option that works for many people. -- Optimists are usually disappointed. Pessimists are either right or pleasantly surprised. I tend to be a disappointed pessimist. |
#2 posted 141 days ago |
Given the saw has the mount for it, I would guess that it came with a riving knife. Maybe its kicking around in the dusty recesses of your b-i-l’s shop? If you can’t find it, DIY is certainly an option. You need to find steel sheet of the right thickness (-just- narrower than the blade), and be picky about how it fits onto the mount, about blade clearance, and make sure it does not sit higher than the blade. I made my own for my old saw and it took three tries to get it right, but definitely improved the saw’s safety. -- Mark Kornell, Kornell Wood Design |
#3 posted 141 days ago |
The BORK is great if it’ll fit. He’s made some nice improvements to it lately. Which Jet saw are we talking about? -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#4 posted 141 days ago |
I’ll find out the model today and post it. I’ll also try posting some pics -- Hey you dang woodchucks, quit chucking my wood!!!! |
#5 posted 141 days ago |
Also check out Shark Guard, they retro fit all types of saw including mine and am very pleased….BC |
#6 posted 141 days ago |
A riving knife is really a simple thing to make if the mechanism |
#7 posted 141 days ago |
why does the knife have to rise and fall with the blade? If you arent cutting through the wood entirely, like dados?? -- Hey you dang woodchucks, quit chucking my wood!!!! |
#8 posted 141 days ago |
If a true riving knife doesn’t work, you can add a splitter to your zero clearance insert. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#9 posted 141 days ago |
That’s a good idea! -- Hey you dang woodchucks, quit chucking my wood!!!! |
#10 posted 141 days ago |
Have you considered that maybe this saw had a riving knife and that your BIL has taken it off? -- Bondo Gaposis |
#11 posted 141 days ago |
What looks like a mount for a riving knife may instead be for the splitter/blade guard. Like on my older Unisaw. Depends on the age of the saw. I’m studying whether I can make my own, but if not, I’ll go for the B.O.R.K. |
#12 posted 141 days ago |
I made a second riving knife easily myself from an old dud sawblade.Needed a larger one for a bigger blade. Just draw out yourshape then cut holding it in a strong vise with a angle grinder with ( my preference) a diamond blade.Careful to remove the teeth section when cutting the saw blank is thinner than the width with teeth attached and poses no width problems.Wear eye glases and gloves too when grinding. I always set my riving knife just a mm or two lower than the height of the blade in question you intend to eventually use this allows for thru and non thru cuts. -- excuse my typing as I have a form of parkinsons disease |
#13 posted 141 days ago |
Runswithscissors has me thinking that it might be a flange for the blade guard actually….. -- Hey you dang woodchucks, quit chucking my wood!!!! |
#14 posted 141 days ago |
”why does the knife have to rise and fall with the blade? If you arent cutting through the wood entirely, like dados??” By definition, that’s what separates a true riving knife from a traditional splitter. There are a lot of options available for a splitter….very few for a riving knife. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#15 posted 141 days ago |
You should check out Leeway. I have a Dewalt Hybrid saw and it had a standard splitter that was hard to install and take out. Now with the shark guard it is easy to change out the splitter between the three sizes since my saw doesn’t have a moving riving knife. Well worth the money I think. He has items for JET. http://www.leestyron.com/index.htm -- Matthew Sherman - http://gosherman.org |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
904 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
