Dyes for wood
Forum topic by RussellAP posted 01-04-2013 12:21 AM 1011 views 0 times favorited 5 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2191 days
01-04-2013 12:21 AM
I don’t know where I was, probably in the projects section, but I saw where a LJ had turned a very delicate pedestal bowl and used a blue dye on it. The wood was a very light color like maple and it turned out beautiful.
I invested in a small bottle of blue dye and can’t wait to try it out.
My main question is, do you dilute it or just dab it on while spinning on the lathe with a cloth?
I want to be able to see the grain so I want to make sure it doesn’t blotch. I would like it to work like any oil, even though I have no idea if it is oil or not, likely water based.
If you’ve ever used it, tell me the ins and outs.
5 replies so far
View Gary's profile
Gary
9293 posts in 3337 days
#1 posted 01-04-2013 12:29 AM
You need to find out what type of dye you have. They can have several carriers. If you put it directly on the wood, you’ll have a mess. Also, there are several methods of dying. You need to let us know which project it was. Some put black on first, sand it mostly off, then cover with the color. There are other ways.
RussellAP
#2 posted 01-04-2013 12:37 AM
Gary, it’s called TransTint. Comes in a 2 ox squeeze bottle. You can mix it with anything, water, alcohol, shellac…
Tell me about this process.
View Gary's profile
Gary
#3 posted 01-04-2013 12:41 AM
I’ll PM you.
View Gary's profile
Gary
#4 posted 01-04-2013 01:08 AM
http://lumberjocks.com/trifern/blog/9400
Here is a like to trifren’s blog on his method. Check out his projects
View cutworm's profile
cutworm
1075 posts in 2698 days
#5 posted 01-04-2013 01:25 AM
Solar Lux Meduim Brown Walnut on maple. Clear lacquer for the topcoat. More red than I wanted.
http://www.thewoodwhisperer.com/videos/you-and-dye/?category_name=finishing
Pretty good primer. I’ve used dye a couple of times and diluted it with alcohol and applied it with a spray gun until I got the color I wanted. I figured you can always add color but can’t easily remove it. I like it because it doesn’t splotch like stain. But it doesn’t give wood the contrast that stain does either.
-- Steve - "Never Give Up"
