Do You Plane Your Face?
« back to Coffee Lounge forum
Forum topic by Eric posted 450 days ago 239 views 0 times favorited 10 replies Add to Favorites Watch
View Eric's profile
Eric
784 posts in 679 days
450 days ago
Topic tags/keywords: shaving shave razor
Hey, how many of you sharpening gurus use a straight-edge razor to shave?
I’ve never done it myself, but figured that since we’re so fond of shaving our arm hairs with razor-sharp plane irons, it would make sense that some of you might shave your facial hair with a straight-edge which you can keep honed to a much sharper edge than you’ll get from a store-bought razor.
-- Eric at http://adventuresinwoodworking.com
View kwhit190211's profile
kwhit190211
32 posts in 651 days
450 days ago
I used to use a straight razor to shave all the time. I got cured of that habit when I went into the service. it damn hard to use one when there are 10 other bodies there in front of the mirror with you. I gave up before I cut my own throat. It’s been a safety razor since for me.
View lew's profile
lew
4487 posts in 651 days
450 days ago
Never used the razor but got the razor strap used on my butt plenty when I was a kid. Hurt then but I think I turned out all the better for it.
Lew
View Loren's profile
347 posts in 543 days
450 days ago
I used one on-and-off for a couple of years. I enjoyed it. The
razor is an antique that has been in my family for a long time.
With my usage the old plastic handles cracked and broke and
it was hard to use it without them.
I’ve had a mind to pick up another ever since… if you have one
give it a try… you probably won’t do nearly as badly as you are
expecting.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
lazyfiremaninTN
528 posts in 848 days
449 days ago
Not on my face, but my barber uses one on the back of my neck and around my ears. Gives me the he-be-ge-bes and I try not to shudder, afraid I’ll lose an ear.
View FlWoodRat's profile
FlWoodRat
584 posts in 804 days
449 days ago
I used to shave my face and cut hair with a straight razor… But I was lazy so my straight razor had replaceable blades. Now that shaving my face means everything above my neck except my eyebrows, I use a Gilette Fusion. I want to keep both of my ears attached.
-- I love the smell of sawdust in the morning....
View Joe Lyddon's profile
Joe Lyddon
485 posts in 948 days
449 days ago
Way back when my facial hair started to “show”, I played with my dads straight razor… I just used the ‘end’ section… above my lip…
Later, I got 7734 for dulling the end point…
I stopped using it… it was SCARY sharp! :) :)
View Rob 's profile
Rob
197 posts in 563 days
449 days ago
I wouldn’t refer to myself as much of a guru of anything but I do use a straight razor from time to time. I inherited an old sheffield hollow ground with an ebony handle plus a strop from my grandfather. The strop comes in handy with the plane irons and chisels. I’m not sure if the razor is as sharp as it should be though, it’ll do the job alright but I can never get as smooth as the safety razor. I’ve heard it’s possible to get a better shave with the straight but I have my doubts.
View cliffb's profile
cliffb
9 posts in 438 days
437 days ago
Never used a straight razor, but I keep my wife’s carving tools “scary” sharp. Yeah, I use my arm to test them. She sure notices if I don’t!
-- I ain't lost. People are always tellin me where to go.........
View LeeinEdmonton's profile
LeeinEdmonton
150 posts in 477 days
437 days ago
I have never been able to use a blade, either safety razor or straight because if I do a rash soon follows. Tried before showers as well as after shows….same result. I can’t even use an electric razor unless the design is rotary blades for the same reason. I’ve been using my current rotary razor for 20+ years by never using the switch but leaving it switched on & then plugging it in & out at the outlet. It’s on it’s third set of blades. Not a particularily great shave but acceptable.
-- Lee
View Gofor's profile
Gofor
109 posts in 682 days
437 days ago
I don’t shave. Need all what little hair I have left to try to hide the ugly.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
