home made drawers
Forum topic by mcoyfrog posted 01-03-2013 07:30 PM 3753 views 0 times favorited 15 replies Add to Favorites Watch
View mcoyfrog's profile
mcoyfrog
4145 posts in 3561 days
01-03-2013 07:30 PM
Hey all
I’m designing a table with drawers and would like some ideas on what you all think is the best drawers NOT using any hardware. I’m looking for the smoothest working I can get. Not going to be a whole lot of weight in them only going to be about 14”x16”x3” deep. Probably going to make them out of pine or cedar so they are light.
If I go with a simple rail system how often would I want to wax them to keep them running smooth, or maybe some kind of really neat engineered something something LOL
Anyway let me know your ideas, and hope you all had a great christmas and happy new year..
-- Wood and Glass they kick (well you know) Have a great day - Dug
15 replies so far
View Loren's profile
10264 posts in 3614 days
#1 posted 01-03-2013 08:32 PM
You make a hole for the drawer with parallel web
frames top and bottom. They have to be parallel
and flat. The sides have to be parallel and square
to the front.
From that point you can make the drawer by fitting
all 4 sides individually to the hole.
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#2 posted 01-03-2013 08:59 PM
Dado a stopped slot in the sides of the drawer and screw runners to the inside of the carcase for the drawers to run on.
-- Bondo Gaposis
mcoyfrog
#3 posted 01-04-2013 04:07 AM
both great idea’s thanks.
Loren have you made or used this type of drawer b4 I interested in seeing some plans.
mcoyfrog
#4 posted 01-04-2013 07:41 PM
Hey Bondo
When doing this I find wood swells with weather do you know of a way to keep this from hindering drawer movement
bondogaposis
#5 posted 01-04-2013 08:07 PM
Yes, you have to be careful and pay attention to wood movement. First allow for a little wood movement by cutting the runners a little narrower than the dados so that the drawer runs on the top of the runner. A 1/16 to 1/8 should be sufficient. Secondly use quarter sawn material for the runners. Quarter sawn has roughly half the movement potential of plane sawn.
-- Bondo Gaposis
View PurpLev's profile
PurpLev
8534 posts in 3615 days
#6 posted 01-04-2013 08:14 PM
there’s always the shop made dovetails slides:
http://lumberjocks.com/gfixler/blog/13478
runswithscissors
2724 posts in 1991 days
#7 posted 01-04-2013 08:43 PM
I’ve used undermount dovetail slides with pretty good success. But the dovetail channel doesn’t have to be thick, if you make it 2 part. You don’t even have to use a dovetail router bit. Just cut the separate sides to whatever angle you like on the TS, then mount front and rear (you’ll need to put a ledge in the back to support that end). The male part is also cut on the TS and fastens to the bottom of the drawer. I like to use a hard, smooth wood like maple. Wax them up good so they slide easily. The nice thing about this is you have some adjustability to vary the tightness of the fit. This only works if you have dividers or a face frame under the drawer. For wider drawers, I have doubled up on these.
I heard about a guy that took great pride in the precision of his woodworking. Built a beautiful chest of drawers with perfect fits. Then everything swelled up and he was never able to get those drawers open again. True story! I, fortunately, don’t have the skill to be that precise.
#8 posted 01-04-2013 09:17 PM
mcoyfrog
#9 posted 01-07-2013 07:42 PM
Thanks again folks
I’m working on a design in sketchup now and will post it when I’m closer to done.
Bondo— didn’t know that 1/4sawn was more stable thanks thats a good thing to know
Purp— thought about doing dovetail but I really suck at them. On a side note I got a dove tail jig last summer and still haven’t figured out how to use it, I think I have some parts missing it just doesn’t seem logical with the pieces I have.
Loren—kewl thanks I’ll read that tonight when I get home and have some more time.
View pintodeluxe's profile (online now)
pintodeluxe
5620 posts in 2779 days
#10 posted 01-07-2013 07:50 PM
Is your reason for not wanting hardware because you don’t want to see the slides? Wood slides require maintenance. Even so, they stick and bind. I have used sliding wood dovetail products, and they just don’t compare to centermount hardware. You can fully conceal centermount slides.
Good luck whatever you decide!
mcoyfrog
#11 posted 01-10-2013 07:13 PM
no real reason Willie just want to, i have a bunch of side mount drawer pulls out in the barn that i got for free or close to nothing when I was working at a thrift type store. They would get lots of furniture and when it wouldn’t sell for a long time they would take it to the dump to be recycled so I had the task of breaking them down, any hardware was mine woot woot.
But anyway I just want to make a non-hardware kinda table for our gaming and see how it goes.
I have some sketchup models I’ll post later i just didn’t get time the other night to export the pics.
thanks for the comment
mcoyfrog
#12 posted 01-11-2013 03:44 AM
table has 6 drawers and legs will fold up so I can lean it up out of the way, haven’t got all the leg locks figured out yet, also the drawers will have locks to keep them from flying open, more to engineer still. Top has a bit of a lip so dice don’t go rolling off. Let me know what ya think.
View longgone's profile
longgone
5688 posts in 3275 days
#13 posted 01-11-2013 04:53 AM
View oldnovice's profile
oldnovice
6771 posts in 3334 days
#14 posted 01-11-2013 07:29 AM
As stated above, UHMW tape and buttons under the drawer sides in the front of the frame takes the weight off of the slides.
mcoyfrog
#15 posted 01-13-2013 03:31 PM
That looks like just the thing for this. Thanks guys
