Thoughts and recommedations on table saw extension table
Forum topic by dschlic1 posted 01-03-2013 02:50 PM 4804 views 0 times favorited 14 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
400 posts in 1846 days
01-03-2013 02:50 PM
Topic tags/keywords: table saw table
I am new to this forum and would like to get some thoughts and advice on designing and building an extension table for my new table saw. Santa brought me a small bench type table saw for Christmas. I used it to make a tool hanging pegboard in the shop area of mu garage. This project started me thinking about how to improve the usability of this saw. The first improvement I am thinking about is to increase the table area of the saw.
I want to increase the size on all four sides of the machine. So I am looking at starting with a 4’ x 4’ table with the saw more or less in the center. When I use the saw, I mount (bolt) it to two heavy duty sawhorses. These provide a very steady and soild stand. Becasue of this I am thinking of mounting the table to the saw, rather than mounting the saw to the table. The two sides of the saw have mounting holes to fasten the table to it. Going this route will allow me to store both the saw and the table seperately in out of the way places.
I intend to frame the table with 1×4 and 2×4 lumber for bracing. I also intend to cover the table, once completed with a laminate (Formica or such). The table of the saw measures 26” wide amd 20” deep. I would like some thoughts and advice on the material to use for the top. Because this table will be portable, wieght is a consideration. I am considering the following materials:
1. 1/2” MDF. Good flat surface, but heavy
2. 1/2” softwood plywood. Warpage my be a problem
3. 1/2” hardwood plywood.
4. 1/4” or 1/8” hardboard. Would need extra bracing, but is light.
I am leaning to using the hardboard.
14 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3035 days
#1 posted 01-03-2013 05:05 PM
I wouldn’t put the saw in the middle of the table just because its dangerous having to reach too far to access the saw and because it might make mounting a fence very difficult. I would suggest searching LJs for tale saw workstations…there are tons of them.
But, basically, I just wanted to bump this…it’s a good question.
Welcome to LJs!
-- jay, www.allaboutastro.com
View NiteWalker's profile
NiteWalker
2736 posts in 2453 days
#2 posted 01-03-2013 06:05 PM
I’d use columbia purebond plywood. It’s poplar core, so it’s pretty light. I haven’t had any issues with warping.
dschlic1
#3 posted 01-04-2013 08:12 PM
I may change the placement of the saw in the table. The reason I first was looking at puttint it in the middle is that this table will really be used only for cutting large sheets and panels. The large size already makes handling difficult. However I wanted to get enough leadin to the saw. The table on the saw measures about 20” in the cutting direction. Once the large peieces are cut, the table will be removed.
Ok, I looked up “columbia purebond plywood” on the web and it is hardwood ply. There is a wholesaler locally, I will have to see if there is a dealer.
runswithscissors
2606 posts in 1901 days
#4 posted 01-04-2013 08:18 PM
I like Baltic birch ply. No voids, smooth surface, many equal thickness plies. Comes in a 5×5 sheet, various thicknesses. Beautiful stuff. Any plywood can warp, however, so you need to check that out when you purchase. Even though I have a pickup that easily carries 4X8 sheets, I have to carry the BB sheets on the roof rack—no big deal as long as you don’t have to drive too far.
You’ll want to route grooves for your miter gauge or crosscut sled.
NiteWalker
#5 posted 01-04-2013 10:43 PM
BB ply is great but can be pretty heavy since it’s pretty much all solid birch wood. Great stuff though; I mainly use it for jigs.
I ordered my purepond online from home depot.
I used it to make my shop cabinets.
View toolie's profile
toolie
2101 posts in 2505 days
#6 posted 01-05-2013 04:01 AM
i’m going to do this with a little 10” c-man POS that i keep wall hung for when friends need a hand on site:
http://www.amazon.com/gp/product/B008MJHT7I/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
View doncutlip's profile
doncutlip
2832 posts in 3432 days
#7 posted 01-05-2013 06:12 PM
Here's what I built
-- Don, Royersford, PA
NiteWalker
#8 posted 01-05-2013 10:37 PM
Don, that’s a real nice outfeed table.
I added it to my faves to hopefully build later this year.
View robjeffking's profile
robjeffking
26 posts in 1982 days
#9 posted 01-06-2013 04:03 AM
Have you considered 3/4 MDF instead of 1/2” for more rigidty. This is how my table turned out using 3/4
View Lynden's profile
Lynden
72 posts in 3023 days
#10 posted 01-06-2013 05:19 AM
dschlic1
#11 posted 01-06-2013 02:40 PM
In my wanderings over the internet I discovered several after market fence systems. I am seriousily considering going that route. Because my saw is rather unique and non-standard, I will have to fabricate a frame out of angle that bolts to my saw that the after markey fences can then be mounted to. A sample design:
Some fences I am looking at:
A very unique fence
Vega Fence System
Biesemeyer 42 Commercial Fence
toolie
#12 posted 01-06-2013 09:39 PM
i’d probably save the money on the much improved fence system and get something like a 4512 from HD using a “20% off any single item” HF coupon. for $400, you’d have a much better fence than you have now and a 1.5hp belt driven dual voltage motor, CI table top, a riving knife, an integrated mobile base, better dust collection, a 3 year guaranty and the backing (with registration) of ridgid’s LSA. guess my feeling is, no matter how expensive the lipstick is that you put on a pig, it’s still, in the end, a pig. unless that’s one very special bench top TS.
NiteWalker
#13 posted 01-06-2013 10:32 PM
+1 on what toolie said. If you’re planning to drop a bunch of time and $$ on upgrading your current saw a new one might be a better choice.
dschlic1
#14 posted 01-08-2013 06:28 PM
Just got a price on fabrication of the metal frame. Way over budget. So I am back to making the table out of wood. I am going to make it out of 1/2” birch plywood. Before that I will need to make some jigs. I will probably start posting these as projects.
