Can I glue oak or walnut that has been previously ebonized
Forum topic by grace123 posted 01-03-2013 02:16 AM 1788 views 0 times favorited 7 replies Add to Favorites Watch
View grace123's profile
grace123
234 posts in 2726 days
01-03-2013 02:16 AM
I am thinking of making end-grain cutting boards. As part of the overall design, I want to use black wood. It is possible to ebonize oak or walnut prior to glue up and then do the glue up with a satisfactory result?
7 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#1 posted 01-03-2013 03:11 AM
Titebond won’t do a good job on wood with any stain but PVA or Epoxy would hold better.
View DKV's profile
DKV
3940 posts in 2468 days
#2 posted 01-03-2013 03:46 AM
What do your test results show?
-- This is a Troll Free zone.
View Edziu's profile
Edziu
151 posts in 3015 days
#3 posted 01-03-2013 05:09 AM
Ebonizing/dyeing/staining wood is only a surface treatment. Unless you can somehow pressure-cook the dye/stain/color into the wood, I can’t imagine it being a very practical cutting board if the color is only ‘skin deep.’
Even walnut end-grain will be nearly black after a mineral oil finish. Consider this project: End grain cutting board with walnut mixed in.
View crank49's profile
crank49
4030 posts in 2935 days
#4 posted 01-03-2013 08:24 AM
Ebonizing, as I understand it, is a process of heat treating wood to obtain color through out the piece. Also called carbonizing and caramelizing. It is a process where the sugars in the wood are cooked to turn dark.
I would think PVA type glue would work on this, but if you can’t test it and if the application is critical, then I would use epoxy.
View WillAdams's profile
WillAdams
81 posts in 1959 days
#5 posted 01-03-2013 11:59 AM
I’ve ebonized red oak w/ the traditional vinegar-rust solution and never had a difficulty in using Tightbond III—but I’ve never depended on gluing end grain—I’d use stopped dadoes and put splines in them to improve the joint—you can add such after ebonizing and take that out of the formula.
View shampeon's profile
shampeon
1775 posts in 2147 days
#6 posted 01-03-2013 06:39 PM
crank49, you’re thinking of torrefied wood. Most of the time “ebonizing” refers to darkening wood with iron sulfate, but some people just refer to treating lighter woods with very dark stain as “ebonizing.”
And WillAdams, the end-grain isn’t being glued. The cutting board surface is end-grain, which makes for a better cutting board because the knife cuts into the end-grain, not across the grain.
I personally wouldn’t use ebonized wood in a cutting board, as I’d worry about it leeching into the food.
grace123
#7 posted 01-08-2013 05:24 PM
Thanks everyone for the comments.
