Turning bottle stoppers
« back to Woodturning forum
Forum topic by mporter posted 141 days ago 438 views 0 times favorited 7 replies Add to Favorites Watch
View mporter's profile
mporter
57 posts in 748 days
141 days ago
I have been trying to turn some bottle stoppers with silicone stopper ends. You use a half inch dowel that the silicone part goes on. Common logic to me would be to glue the dowel into the blank, chuck the blank into a Jacobs chuck and turn. However the dowel always breaks during turning. I’m using a oak dowel. What am I doing wrong? How do you guys turn these? I am very new to turning so any help would be appreciated.
7 replies so far
View Mike's profile
Mike
259 posts in 858 days
#1 posted 141 days ago
This is what I use to turn my bottle stoppers. Click here
-- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com
mporter
#2 posted 141 days ago
Yeah I have a bottle stopper mandrel and it works great if I am using those chrome stoppers that screw on. But I am having problems with the other kind that go on a half inch dowel.
View JesseTutt's profile
JesseTutt
707 posts in 281 days
#3 posted 141 days ago
Chuck the dowel in the headstock’s chuck and then use a live center in the tailstock to hold the back end as long as possible. You should be able to get most of the bottle stopper turned before you have to part of the tail stock’s waste.
You might check out some of Ron Brown's DVDs.
View kipperdude1's profile
kipperdude1
3 posts in 655 days
#4 posted 141 days ago
one turner I was talking to sujusted cuting a peice of 1/2” all thred rod to use as a mandrel in the jacobs chuck. I havent tried this my self but might work or you can buy a pin mandrel sized for 1/2” or eavean makew one your self take a peice of 1/2” all rod mill a small flat about 1/4” in from the end about 3/4” – 1” wide and deep enough so you can slide a blank on with the 1/8” pin in the flat so it pinches up to hold the blank with a slight turn . you will want to mark the top side of the mandrel to locate the pin on the top so you wont lose the pin on the floor
Hope this will help
View lumberjoe's profile
lumberjoe
2401 posts in 419 days
#5 posted 141 days ago
I have the PSI chuck/mandrel posted above, it works awesome and is EXTREMELY simple. PSI shows out of stock but I am pretty sure woodcraft also carries it (I bought mine in the store).
-- http://www.etsy.com/shop/KandJWoodCrafts
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#6 posted 141 days ago
I use the Ruth Niles Morse taper mandrel. Linkhttp://www.nilesbottlestoppers.com/stoppers.html#Special.
-- Bondo Gaposis
mporter
#7 posted 140 days ago
Thanks for all the help guys. I think I have it figured out now.
