Need lathe tool set suggestions
« back to Woodturning forum
Forum topic by yellowtruck75 posted 135 days ago 531 views 0 times favorited 10 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
329 posts in 1232 days
135 days ago
I have had my lathe for a few years now and have mostly turned small items like pens and bottle stops. Recently I started turning larger bowls (>11”) but my lathe tools are not the best. I need suggests for a nice set of tools to use while turning bowls. I am teaching myself how to turn bowls so i apologize for my ignorance on the subject. I want a decent set but don’t want to spend hundreds of dollars.
My lathe is a Jet 12-20.
I have all the necessary chucks that I need.
10 replies so far
View Wildwood's profile
Wildwood
342 posts in 300 days
#1 posted 135 days ago
Either ¼” bowl gouge actually 3/8”, or 3/8” actually ½”.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=100120&Category_Code=tools-pkrd-bg
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=100121&Category_Code=tools-pkrd-bg
Heavy duty round nose scraper.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=100126&Category_Code=tools-pkrd-hdrndscpr
They also carry thinner scrapers but that heavy duty scraper will serve you better.
Buy any two Packard brand (Hamlet) tools and save 10%. If buy three Sorby also save 10%.
I recommend M2 HSS tools you can always buy exotic steel tools later.
Other vendors also offer 10% off when buy two or more tools do not forget to ask:
http://www.woodturnerscatalog.com
If buy these tools unhandled prices not bad. Bought a 5/8” bowl gouge for roughing out unhandled and it is okay prefer my old worn out Crown M2, 5/8” bowl gouge.
http://www.thompsonlathetools.com/
-- Bill
View bobasaurus's profile
bobasaurus
684 posts in 1349 days
#2 posted 135 days ago
I like robert sorby turning tools. I have a bowl gouge and scraper from them and both work great.
View dontlikenicknames's profile
dontlikenicknames
3 posts in 365 days
#3 posted 135 days ago
I have three lathes and drawer full of turning tools that include a set of Sorby. Sorby are nice but save your money. 99.9% of what I do is with a bowl gouge
yellowtruck75
#4 posted 135 days ago
What os the difference between a bowl gouge and a fingernail bowl gouge?
View wlhutch's profile
wlhutch
55 posts in 1685 days
#5 posted 135 days ago
Before you buy tools, I would suggest that you get a book or DVD on turning bowls. Richard Raffan, Mike Mahoney and Bill Brumbine teach basic bowl turning techniques along with tool selection and use. Your tools will be useless without a sharpening system to keep an edge or grind a particular bevel.
Once you know what you need, then tool selection will be easier. As stated above, Thompson lathe tools are a good place to start with obtaining quality steel.
View gtbuzz's profile
gtbuzz
144 posts in 607 days
#6 posted 135 days ago
I’d agree with dontlikenicknames. I end up using a cheaper bowl gouge that I bought with a set from Highlands a while back along with a round nose scraper for the majority of bowl turnings.
Having said that (and I also know that you said you don’t want to spend may $100’s), I recently picked up some Easy Wood Tools carbide tools (the full size rougher and the finisher) and am quite enamored with them. They’re significantly easier to use than the traditional turning tools (although if you’ve figured out a skew chisel, chances are you can figure out a bowl gouge). They haven’t replaced my old tools as I find I like using a mix of all of them, but they definitely shoulder a brunt of the load now.
Also +1 on Raffan’s bowl turning DVD. It’s an excellent watch and great for helping to learn some of the basics.
yellowtruck75
#7 posted 135 days ago
I just ordered two of Raffan’s DVDs. Look forward to watching them this weekend.
View RVroman's profile
RVroman
160 posts in 189 days
#8 posted 135 days ago
The difference between a bowl gouge and a fingernail bowl gouge is the grind on the tool. My personal preference is the fingernail, but that is a difficult grind without a jig.
Standard grind
Fingernail grind
I pretty much use two tools when doing bowls, a 3/8” bowl gouge with a fingernail grind, and a 3/8” spindle gouge. (they both happen to to be Sorby, but I also have other tools that are hamlet, pinnacle, and wood river. Any of those would be fine. Sorby’s are nice, but you do pay for the name)
There are opinions galore on the use of scrapers and such when doing a bowl, the best thing I can tell you there is to research it and make the decision that is best for you and your turning.
-- Robert --- making toothpicks one 3x3x12 blank at a time!
Wildwood
#9 posted 135 days ago
Fingernail is just the grind we put on whether bowl or spindle gouge. Normally tools come with a straight across and we grind to fingernail or side ground. You can buy tools already ground to fingernail or side grind style.
Side, Irish, or Ellsworth grind all the same thing. David Ellsworth and other vendors sell a jig so can achive a side grind. Wolverine gives instructions for obtaining both fingernail and side grind on your tools.
You can now buy a jig if want to put a double bevel on your bowl gouge. Called a Vecter Grind Fixture.
Scroll down: http://www.woodturningonline.com/
-- Bill
View WJS's profile
WJS
54 posts in 1038 days
#10 posted 134 days ago
You need to sharpen them a bit more often than Sorbys, but I have been pleased with the Benjamin’s Best tools from Penn State. Great for beginning, and cheap enough that you don’t feel bad experimenting with different grinds. (btw, i think that the Ben. Best are identical to the Bodger tools sold by Highland.)
With regards to the grinds, I have found that I end up using a couple of different gouges with different grinds on them depending on the shape/angle of attack of the bowl
Ditto on getting a book/dvd. Turning bowls can be a bit dangerous and there are several important differences between turning a bowl and turning between centers.
I don’t know if you have some kind of sharpening jig, but there are several different plans for “homemade wolverine jigs” on this site.
-- Hello, my name is Jarrod and I am a woodaholic.
