Moving table saw down stairs
Forum topic by doncutlip posted 92 days ago 460 views 0 times favorited 30 replies Add to Favorites
View doncutlip's profile
doncutlip
17 posts in 92 days
92 days ago
Topic tags/keywords: question
I want to buy a table saw, but am now sure how I’m going to get it into my basement. It has to go down the stairs that came with the house; just 1 inch pine boards on the sides. The treads and risers are stapled into the sides. It doesn’t look like it can hold that much. Anyone know how much weight can go down them, or any tricks for doing this?
What are the consequences of taking a saw all apart and moving it one piece at a time?
-- Don, Royersford, PA
View Roper's profile
Roper
410 posts in 249 days
92 days ago
stairs are pretty tough short of dropping something really heavy on them you should have no problem bringing it down.
-- Roper - master of sawdust-
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
92 days ago
Several tips:
Break the tool into smaller sections. Simply removing the motor can make a difference. You could also remove the wings.
Run a pair of 2×8’s down the stairs to spread the load across many steps. This will also enable you to slide the tool down.
Make sure the stair case is properly attached at the top. I’ve seen the occasional cracked tread (hence the 2×8’s), but the only real failure I ever saw was a basement staircase that came undone where it met the upper floor. The entire premade staircase came down as a unit!
-- - Real men read directions
View Tom Adamski's profile
Tom Adamski
226 posts in 307 days
92 days ago
The saw will be easy… wait till you need to get a sheet of plywood down there!!!
Disassemble the saw, cary it downstairs and put it back together.
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
doncutlip
17 posts in 92 days
92 days ago
Yeah, how the top attaches is hard to see. All I see in the top riser is a couple of nails. (Can’t see attachments on the side at all.) Someone told be it’s “bullnosed” into the upper floor – I”m not sure what that means. It doesn’t attach at the bottom, I also hear I should nail a cleat to the floor, which is concrete. The saw I really want is 435 pounds (Steel City 35900); would I have to also bolt some supports to the underside, and where would they go, on the sides or under the treads?
View bbqking's profile
bbqking
275 posts in 260 days
92 days ago
I agree with Roper and Beechpilot-the stairs will hold and make a ramp. You’ll be fine. Also to BeechPilot if you are still out there, do you fly a Bonanza? My father did for years for fun and to take us to dinner in Chicago & etc. back in the 70’s. As always, bbqKing
-- bbqKing, Lawrenceville
BeechPilotBarry
92 days ago
BBQ King…
I’ve got a Sundowner, which is like a Piper Archer (Cherokee 180) with an extra door and more room.
We’re currently looking at Bonanzas, Piper Saratogas, and Cessna 206’s to get there sooner… <g>
BeechPilotBarry
92 days ago
Doncutlip:
How old is the house? Newer houses are more likely to have a purchased staircase improperly attached.
Does the staircase appear to be a manufactured item or built in place? Same reason as the previous question.
Are there walls on either side of the stairs, or do the stringers run through clear air from top to bottom? Walls provide lots of support to stringers.
If you were to step off the bottom step and walk straight ahead, how far to the wall? Instead of nailing a cleat, 2x lumber can be wedged between the wall and bottom stringer edge. Wood is strongest in compression, and you won’t have to worry about chipped concrete.
The staircase I saw collapse was a pre-built “home center” unit, inside a “Bilco” exterior door. It was attached to the mud sill with a total of (2) framing nails. A person was carrying PA equipment for his band into the basement, when the staircase disconnected and fell. The total load on the stairs was less than 400 pounds. The fall victim made a full recovery, but it hurt for a long time. 8^(
doncutlip
17 posts in 92 days
92 days ago
The house is 15 years old. Can’t say if it’s prefab stairs; the treads and risers are fitted with triangular shims. Sides go straight through without support. And I only see the two nails you mention (perhaps one more one one side). Good idea on the bottom, it’s about 30 inches to the wall. But that’s another problem, even if the saw fits at the bottom, there’s no room for people to work it; I think I’ll have to build a platform a couple of steps up. Sounds like I can’t trust these stairs at all, might have to take the saw apart. Didn’t want to have to do that, but oh well.
BeechPilotBarry
92 days ago
Think of the disassembly as “maintenance training”.
View motthunter's profile
motthunter
1234 posts in 335 days
92 days ago
With boars in place as runners, you should have no trouble. Just make sure that you have enough help to keep it from falling.. Keep it all in control and it will go down easy…
-- making sawdust....
View FlWoodRat's profile
FlWoodRat
308 posts in 445 days
91 days ago
How about this alternative, in lieu of taking it through the house and down the stairs, build an access area to your basement from outside the house. Excavate a 16’ long by 8 foot wide sloped ramp, pour a footer, lay block up the side, pour a concrete ramp with rail track. Then, install a 7’ tall by 6’ wide set of french doors into the basement. Imbed a hoist assembly that you can use to lower your assembled saw.
Never mind, using 2/8’s as runners on your stairs would be easier.
-- Smile. Life can be FUN!
View thetimberkid's profile
thetimberkid
1684 posts in 239 days
91 days ago
My suggestion is many hands makes lighter work!
Good luck
Callum
-- Look great, get your TTK merchandise now! http://www.printfection.com/thetimberkid/ Check out my site http://thetimberkid.blogspot.com/
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
277 posts in 133 days
91 days ago
Another thought, when we moved into this house the movers had to get all the heavy stuff into the basement, the biggest piece that would not disassemble was 500 lbs.
We have a bilco door and stairs, just to be safe I bought some 2×4s and ran them as vertical supports under each step. So each step then had its own vertical support going to the floor. I centered the support width wise and as close to the front edge of the step as possible, there are no risers, just steps.
That will give you piece of mind, but the 2×8s ramps should be enough.
-- Rich, WNY, www.nyrockingchairs.com
View Loren's profile
248 posts in 184 days
91 days ago
it seems crazy when you consider all these lucid, well-thought replies.
I’ve moved a lot of machines by the seat of my pants. Getting them
up stairs is a helluva lot harder than down in general.
I would probably take the wings off and strap it to a hand-truck
(preferably with big tires), get a helper on the bottom to slow
it down and bump, bump, bump – down you go. Unless your
saw is an antique behemoth you should be able to move
it quickly and easily this way with two fit men (you being one
of the two).
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View SCOTSMAN's profile
SCOTSMAN
538 posts in 121 days
91 days ago
listen I know guys who have taken heavy metal lathes and bridgeport milling machines down to their basement so lighten up it’s a piece of cake whaT YOUR DOING.I have taken a big felder saw with a cast iron base and a spindle moulder all in one into my workshop up stairs and then up the garden before installing it in my woodshop so good luck Alistair ps excuse my poor typoing
doncutlip
17 posts in 92 days
91 days ago
Thanks for all the replies. The only thing I’ve seen go down these stairs was my jointer, about 225 pounds and we just slid the box down the treads. I have a friend who is a material handler at work, I’m hoping to get him over here and have a look at things. I have the money, I know what I want (Steel City 35900) and I have a birthday coming up. The heaviest piece is 435 pounds; and I suppose I could take the motor out. I like the idea of bracing the underside, I’ll just have to remove some custom built shelving I have under there. It just has small screws through angled half-lap joints in the sides, so I doubt that would hold up much. Getting close to pulling the trigger on this thing. Does anyone know if drivers are willing to drop the crate in a garage, or are they hamstrung by insurance to leave it at the curb?
6697 posts in 387 days
91 days ago
As BeechPilotBarry says try to break it down. If if has a cast iron top it might be in two or three sections, they are heavy items as well as the motor.
View CharlieK's profile
CharlieK
15 posts in 329 days
91 days ago
I have a cabinet saw and a heavy bandsaw in my basement. I hired piano movers to get them down the stairs. They had it done SAFELY in 10 minutes! Well worth the money in my book.
View ajosephg's profile
ajosephg
99 posts in 97 days
91 days ago
I’d vote for hiring piano movers. Considering how much you paid for the saw a few bucks more for some experts would be a good investment considering all the bad things that can happen like the guys beneath the saw if it gets away.
-- Joe
View Steelmum's profile
Steelmum
198 posts in 499 days
91 days ago
My husband is a gun collector. We had a gun safe upstairs. When we moved we hired movers, found them in the yellow pages. I think the name was something like 3 guys. We hired them for an hour and they moved the safe and everything else down those narrow cape cod stairs. Hire movers.
-- Berta in NC
doncutlip
17 posts in 92 days
90 days ago
Joe,
Your comment really hits home; should I subject my friends to this kind of risk? I’ll get some quotes from movers. Plus I’ll have that friend of mine come over and have a look, he does have experience with these sort of things.
ajosephg
99 posts in 97 days
90 days ago
In the event you do decide to move it with your friends, I’d also make the following suggestion – Tie a big rope or chain, or cable to it and anchor it to a suitable anchor (auto?) Many years ago I helped my neighbor move a full size upright piano out of his basement. We planked the stairs (after doing a structural analysis) and tied a big rope around the piano and hooked the rope onto a car so that we did not have to depend on muscle power alone. The geometry was such that we could get a fairly straight shot at the stairs and we used my Intl Scout 4×4 in low low gear so it was easy to move forward really slow. I think a better way would be a come along or block and tackle.
Seeing how I was young then, and now that I am old I still think the pro’s are the way.
-- Joe
View poopiekat's profile
poopiekat
84 posts in 270 days
90 days ago
A side note to those contemplating the labor of a truck-driver as mentioned above.
If you make your purchase with the expectation of freight delivery, you are going to have to deal with this: Most trucking companies will charge more for ‘Residential Delivery’ because the truck will be far afield of its normal routes. Freight rates are based implicitly on so-called ‘curb delivery’ and that means either the driver will move your freight to the tail of the trailer, or, in some cases the obligation ceases once the freight hits the ground, which requires the use of a trailer with a lift-gate, for more money. You can call the local dispatcher and request “Inside Delivery” but that will be another big surcharge. Explain to the dispatcher that you wish inside delivery and down a flight of stairs….they might refuse, or sub-contract the actual delivery to an outside source from the local freight depot to your basement. I knew of one guy who ended up removing his basement stairs and using a gantry and chainfall to lift and swing an old milling machine down the empty stairwell. At least the labor of tearing the machine down was avoided.
-- If Stradivarius was alive today, he'd be using Gorilla Glue.
doncutlip
17 posts in 92 days
88 days ago
I have a friend who cut through his upstairs ceiling to expose joists and installed a couple of block and tackle systems. Using come-alongs, he took a 935 lb geothermal heating unit down some oak steps. No way I’m going that far. Sadly, all this has to go on hold as I have gall bladder surgery this Friday.
2078 posts in 558 days
88 days ago
Don I hope your meds are doing it with a scope and a lasso.
That one hardly gives you time for flowers.
Good luck
doncutlip
17 posts in 92 days
88 days ago
Well, I hope it goes that way; and doc says it’s a good chance it will. You know if there’s restrictions, like I can’t drive for a while or something?
ajosephg
99 posts in 97 days
88 days ago
Couple of my friends had gb surgery recently and were back working in 2 days. Only restriction was not to lift anything heavier than 20 lb. for two weeks. (using laparoscopy or however it’s spelled.)
-- Joe
doncutlip
17 posts in 92 days
83 days ago
Well, I’m on the mend now. No way I could make it back after 2 days out. Recovery at home gives me time to plan the electrical side of things.
View jm82435's profile
jm82435
237 posts in 278 days
83 days ago
might ask Spalm, he just went through this taking his new 400lb Steel City saw to his basement.
-- A thing of beauty is a joy forever... - Keats
View SPalm's profile
SPalm
742 posts in 418 days
82 days ago
Here is a copy of the message I sent to Don about my recent experience.
I stressed over this for years, and it delayed my purchasing. Not if the steps could handle it, but if I could actually muscle it. All in all, it went much smoother than anticipated. The saw probably weighs more in the 300 range without the wings and the fence. The wings and fence rails are really heavy. I strapped the saw to a two wheeler that had pneumatic wheels and got it down pretty much by myself with another guy below it just incase. I am only 5’8” and 55 years old. The soft wheels really helped the bumpy ride.
I would really think that the stairs could handle 300+ pounds. Some large people weigh this much. You could grab a couple of friends and all stand on the stairs together to try it. Although this sounds like a stupid way of testing, it just shows you how I believe your concerns are over cautious. Or put another way, if it can’t hold people, you should brace and fix it for safety sake.
Steve
Bookmark And Share This Page
