"Squaring" the framing square
Forum topic by niki posted 05-22-2007 09:41 AM 8054 views 2 times favorited 14 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 4278 days
05-22-2007 09:41 AM
Good day
I have two framing squares but non of them was “Square” and then, one day I saw this method on the Internet.
It’s almost impossible to square both sides because usually the “Legs” are not consistent in width.
I selected to square the out-side because I use it the most.
Regards
niki
14 replies so far
Dick, & Barb Cain
8693 posts in 4498 days
#1 posted 05-22-2007 12:36 PM
Thanks Niki,
I’ve used this method, & it works good. It’s good to inform others as well.
18618 posts in 4359 days
#2 posted 05-22-2007 12:37 PM
well isn’t that interesting!!! I would have just bought a new one and tossed the old one into a box somewhere
-- ~ Debbie, Canada (https://www.facebook.com/DebbiePribele, Young Living Wellness )
View Tony's profile
Tony
986 posts in 4229 days
#3 posted 05-22-2007 12:41 PM
Excellent Tip, I checked out my Square, but it was spot on – inside & outside angle, so I did not check out the angle adjustment.
View Sawhorse's profile
Sawhorse
281 posts in 4639 days
#4 posted 05-22-2007 01:58 PM
Great tip, I’ve red this before, but the pics really make it easier to understand what I’ve read.
-- Sawhorse - Sulphur Springs, TX - www.sawhorseworkshop.com
View gizmodyne's profile
gizmodyne
1780 posts in 4288 days
#5 posted 05-22-2007 03:54 PM
Great advice, once again. Thanks Niki.. I must check my squares.
How do you fix a square with a wood base?
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
View Don's profile
Don
2603 posts in 4375 days
#6 posted 05-22-2007 04:23 PM
Nicely explained old carpenter’s trick. Thanks, Niki.
-- CanuckDon "I just love small wooden boxes!" http://www.dpb-photos.com/
View USCJeff's profile
USCJeff
1065 posts in 4267 days
#7 posted 05-22-2007 05:10 PM
Good job. I did something similar last night based on Wood magazine’s recent article, “Don’t Swear, Get Square” 07/07
-- Jeff, South Carolina
View David's profile
David
1969 posts in 4337 days
#8 posted 05-22-2007 05:14 PM
Niki -
Great advice! I read about this method in Finehouse Building. As usual, your excellent labeled photos really clarify this approach.
View niki's profile
niki
#9 posted 05-22-2007 10:31 PM
Thank you for your kind words
As I said, the punching idea is not mine, I just added some “colors” to the method and checked with knives instead of the traditional “pencil line” for better accuracy.
Debbie
My wife is the same…one day I saw her going with the home vac to the trash…”why”, I asked… “it’s not working”, said she.
I checked and found one wire disconnected at the plug…
Gizmodyne
I have no idea how to correct the one with wood base, usually I make them myself and I don’t need any correction.
If you remember the post “Triangles – copy and past” – after you “copy” the triangle, set the router table fence to, say, 2” and route from both sides till you get try-square that will be very accurate on all the sides.
I think that if you make it from 1/2”~3/4” plywood it will be more stable than any other 2 parts try-square.
niki
View Dollarbill's profile
Dollarbill
91 posts in 4336 days
#10 posted 05-23-2007 01:52 AM
Niki, Strange that you write this now. Two days ago I was trying to adjust my framing square and I couldn’t get it right. After I fooled with it for about 30 minutes I discovered that the short leg was not straight but bowed. I put it on my TS and found that it rocked and that the high spot was at about 3 1/2 “s. I took a file and SLOWLEY filed in that area until it didn’t rock and seemed straight. It is a cheap square stamped out of aluminum with a thick clear coating on it (us skinney old guys like light tools). Works great now but I think your idea with the knives is better than my scribe line.
Bill
-- Make Dust
View mot's profile
mot
4922 posts in 4235 days
#11 posted 05-23-2007 04:28 AM
Thanks for this tutorial. Someone once described this to me, but it didn’t register until I saw your pictures! Thanks!
View WayneC's profile
WayneC
13783 posts in 4296 days
#12 posted 05-23-2007 04:30 AM
Thanks Niki. Clear and easy to understand as always.
View catapix's profile
catapix
1 post in 3416 days
#13 posted 08-04-2009 01:32 PM
Any chance of you re-uploading the pictures (again?).
It’s a pretty old topic so I understand if its not possible or worth it.
I’m new to these fora and boy does it have a ton of tips, and I’m really enjoyed over your jig constructions,
can’t wait to get into the workshop and test them myself.
Thanks for sharing.
View niki's profile
niki
#14 posted 08-05-2009 02:40 PM
Re-loaded….
niki
