Ripped Cherry warped
Forum topic by PaulLL posted 01-02-2013 01:11 AM 1073 views 0 times favorited 8 replies Add to Favorites Watch
View PaulLL's profile
PaulLL
160 posts in 2218 days
01-02-2013 01:11 AM
Hey guys, I just ripped a 7” x 3/4 length of cherry into 3 2” pieces, after I was done, one of the pieces curved out really bad, starting right in the middle of a ring on the board. I was planning to use the pieces to make a couple cabinet doors and the ring was going to be in the center so it lined up when the doors were closed. I’ve been trying to see if anyone had a way to fix that, or is it a standard thing for a board to curve at the center of the rings? Most of the post I found were pretty old, so hoping someone has found the answer since! I attached a pic so you can see what I’m talking about. The board has been standing leaned against the wall for almost a year and half, so I’m pretty sure it should be totally dried out and I didn’t have any issues with the rest of the same lumber, which I’ve been using to build an aquarium stand with. Thanks guys.
Paul
8 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3802 days
#1 posted 01-02-2013 01:29 AM
I’d guess that the ring was where a branch and the branch caused stress in the trunk as the tree grew. When you cut through that area the stress was released and caused what you see. Not knowing exactly how you intended to use the board I can’t give you an informed opinion on what to do other than start over with a different piece of stock.
-- Joe
View Nicky's profile
Nicky
695 posts in 4333 days
#2 posted 01-02-2013 01:31 AM
The board had some internal stress due, most likely to the “cathedral grain pattern.” This is common.
How tall are the doors?
-- Nicky
View Dallas's profile
Dallas
3599 posts in 2728 days
#3 posted 01-02-2013 01:39 AM
A not easy, not quick and not guaranteed fix is to steam the warped piece a foot or so on each side for awhile then place it on a small block so it is held up in the center and clamp the ends down until it dries.
Again, it’s not guaranteed, but it does work, ..... mostly.
View crashn's profile
crashn
528 posts in 2707 days
#4 posted 01-02-2013 02:45 AM
The moisture content of the wood really had nothing to do with it warping at this point. Purely internal stresses in the wood. Just happens sometimes. Sometimes, if you were cutting into smaller pieces, you can work around a bow.
-- Crashn - the only thing I make more of than sawdust is mistakes
PaulLL
#5 posted 01-02-2013 03:59 AM
A branch, I never thought of that, interesting to know, thanks for that tip, ajosephg. Dallas, I did try to bend it with a piece underneath, being a welder that works well with metal, it didn’t bend this back. Although I didn’t add steam, would I do that with an clothes iron?
Nicky, the doors are 22” but I wanted the circle to meetup in the middle when the door was closed, that’s why I’m asking if I can fix it, I think that will one of those small details that’ll look so good, I’ll be the only one to notice! ha
Thanks guys
Nicky
#6 posted 01-02-2013 03:56 PM
Paul,
You are cutting a 22” piece from a 7’ length. The bow will be greatly reduced after your cut. You could just joint the edge after the cut (jointer or hand plane). I don’t think that will alter the effect that you’re after.
-- Nicky
View me5269's profile
me5269
43 posts in 2409 days
#7 posted 01-02-2013 04:01 PM
I’ve used Dallas’s suggestion for steaming on some 13” x 14” 3/4 cherry (2 1×8 glue-ups that had been sitting for a few years) that had cupped. Bought a cheap steam iron (this process will ruin the base plate), soaked an old towel with water, covered the wood and “ironed” it on highest temp. The wood actually cupped in the opposite direction after about 5 minutes of ironing. Then clampled the pieces (4) together, with stickers between them, on the end of workbench for about a week. I used them the day they were unclamped in case the cupping returned. Have never tried it on a warped board.
-- Mike
PaulLL
#8 posted 01-03-2013 04:18 AM
Nicky, its 7” wide. The board is only 50” long, but to get the ring I want its right at the curve.
me5269, thanks for the tip, Im sure my wife wont mind me using the iron, she hates ironing anyways!
