DW735 Planer Bolts: Just Learned a Hard Lesson!
Forum topic by jasoncarpentry posted 01-01-2013 08:50 PM 3063 views 1 time favorited 20 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
142 posts in 2654 days
01-01-2013 08:50 PM
Those of you who have the Dewalt 735 planer might have experienced this problem. The 24 bolts which fasten the knives to the cutterhead (eight per knife) are made of cheap steel (carbon steel?). They tend to “freeze,” even after just hand-tightening. And more often than not, my efforts to remove them have resulted in a rounding off of the hex inset; I then have to use a bolt extractor to take them out, which ruins the head.
The good news is that stainless steel bolts have a deeper hex, and, being harder material, are much less likely to round off. So, I’ve ordered 24 replacement SS bolts; until then, I have a mixture of CS & SS bolts. Now here comes the hard lesson: I added lock washers to all of the bolts to make them easier to remove, and then made a few passes on a hard-to-make laminate. The result? Dark, slightly deep gouges along the length of the workpiece.
Being the genius that I am, I immediately stopped planing, opened up the planer, and removed all of the lock washers. The heads of the CS bolts showed a slight degree of flattening, which means that there’s no “forgiveness” in the cutterhead clearance. The lock washers had simply raised the boltheads up too high to avoid contact w/ the workpiece.
So, if you’re tempted to add lock washers (or just plain flat washers) to the bolts, DON’T DO IT!! Has anybody else had this problem w/ the DW735?
-- Jim in Tennessee
20 replies so far
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#1 posted 01-01-2013 08:54 PM
The first time I changed my blades, I could tell they were torqued on there pretty good. However on subsequent changes, I have had no problems. I blow the dust out of the bolt heads, which lets me seat the allen wrench all the way into the bolt.
Thanks for the heads-up on the lock washers.
View teejk's profile
teejk
1215 posts in 2684 days
#2 posted 01-01-2013 09:06 PM
I think you find the same problem on jointers…most likely the legal department got involved and mandated LokTite on the threads…a bear to remove the first time (bandaids not included).
View ajosephg's profile
ajosephg
1880 posts in 3560 days
#3 posted 01-01-2013 09:11 PM
I put a drift in the bolt socket and give each bolt a good rap before trying to loosen them. Haven’t stripped one yet.
PS – Also put some anti seize compound on the bolt threads before re-installing them.
-- Joe
View rockindavan's profile
rockindavan
299 posts in 2635 days
#4 posted 01-01-2013 10:18 PM
Never needed to use lock washers. If you are so inclined, your could try star washers. They are a bit thinner than the standard split washers.
jasoncarpentry
#5 posted 01-01-2013 10:22 PM
ajosephg-
At the risk of appearing stupid, what’s a “drift in the bolt socket”?
-- Jim in Tennessee
View SnowyRiver's profile
SnowyRiver
51457 posts in 3480 days
#6 posted 01-01-2013 10:36 PM
I noticed on mine that the first time that I had to change the knives I almost broke the handle off of the hex wrench they give you. I have noticed now that each time I flip or replace the knives that they come off much easier. I think the factory just over tightens them.
I think Joe is talking about a drift pin…its like a center punch. The rap on the bolts loosens the seal on them.
-- Wayne - Plymouth MN
ajosephg
#7 posted 01-01-2013 11:06 PM
Jim – as Wayne said, basically a center punch without a point.
http://en.wikipedia.org/wiki/Drift_pin
-- Joe
Craftsman on the lake
2791 posts in 3437 days
#8 posted 01-01-2013 11:20 PM
for my 734 it was the factory tightening. I have a bosch combo drill driver. I used the driver in reverse to unseat them as it has a hammering effect.
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#9 posted 01-01-2013 11:31 PM
Havent had my 735 long enough to hafta change the blades. But I’ll certainly be watchful for this when the time comes. I have a box full of stainless bolts, will look to see if I have enough to change them out
Thanks for the tip.
View robjeffking's profile
robjeffking
26 posts in 2105 days
#10 posted 01-01-2013 11:39 PM
Same problem here with my 13-580 delta every bolt came out except for one there always ONE that has to be a pain.
Tried all the usual solutions ended up having to grind the head off the bolt.
View RVroman's profile
RVroman
163 posts in 2023 days
#11 posted 01-02-2013 12:38 AM
I have made about 3 blade changes on mine and have not had a problem. Of course saying that means the next time something bad is going to happen…...
-- Robert --- making toothpicks one 3x3x12 blank at a time!
View lew's profile
lew
12061 posts in 3755 days
#12 posted 01-02-2013 12:46 AM
After reading the horror stories about these bolts, I went to Fastenal and bought replacements. Same dimensions but harder steel. Also used a dab of anti-seize on each one when exchanging them. So far so good.
View Straightbowed's profile
Straightbowed
717 posts in 2297 days
#13 posted 01-02-2013 02:05 AM
troque them at 400kmgf
-- Stevo, work in tha city woodshop in the country
Straightbowed
#14 posted 01-02-2013 02:06 AM
TORQUE them at 400 to 500 KMGF
Straightbowed
#15 posted 01-02-2013 02:08 AM
I almost had the same problem but I just bought a gross of bolts and a small torque wrench problem solved if the allen doesn’t feel right I pull the bolt and put a new one in before it happens
