Preserving a wood sculpture
Forum topic by Post_Oakie posted 01-01-2013 07:05 PM 1923 views 0 times favorited 2 replies Add to Favorites Watch
View Post_Oakie's profile
Post_Oakie
84 posts in 2122 days
01-01-2013 07:05 PM
Topic tags/keywords: norwood sawmill insects in wood
While cutting logs for my portable sawmill, I came across an ant colony in an ash tree. My first thought was “dang, that log is rotten.” But this piece is beautifully sculpted by the little critters (I don’t expect they were any more pleased to see me than I was to see them). Question is, how do I preserve it, and bring out the grain? I’m thinking of soaking the whole piece in hot liindseed oil. Any suggestions? Thanks!
-- Good judgement comes from experience. Experience comes from bad judgement.
2 replies so far
View Dan Krager's profile
Dan Krager
3969 posts in 2203 days
#1 posted 01-01-2013 07:31 PM
Hot LO would be a good start. I think I would recommend the raw stuff, not the stuff that dries into a finish (BLO), because you won’t be able to wipe it down enough to prevent the dried collections in corners you can barely reach. You could blow it “clean” with compressed air first, soak it, and blow off the excess oil. If you are going to keep it indoors, not much more may be needed.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
Post_Oakie
#2 posted 01-01-2013 08:29 PM
I like the idea of blowing it off with compressed air. Oh yeh, it will definitely stay indoors, maybe as a book end or decorative piece. Thanks!
