JDS Dust Collector
Forum topic by Dusty56 posted 01-01-2013 06:12 PM 2622 views 0 times favorited 16 replies Add to Favorites Watch
View Dusty56's profile
Dusty56
11819 posts in 3681 days
01-01-2013 06:12 PM
Topic tags/keywords: question dust collector jds
Hi , I just picked up a JDS B500101-1 dust collector from Craigslist. The guy was asking $100 , but I left with it and some hose and accessories for $75 : )
The owner doesn’t know the micron rating of the top bag and I haven’t been able to find out online as yet. Anyone own one that might have the info ?
All I can find at their website is the newer model which appears identical and is listed as a 1 micron bag.
This unit has a 16 amp draw on start up at 115 volts but can be rewired to 8amps at 220volts. Fortunately when I had my shop wired , I asked the electrician to install 20 amp circuits along with the 220 volt that I had asked him to do while he was there. : ) Money well spent.
Thanks for your help , and Happy New Year to all of you !
16 replies so far
View PurpLev's profile
PurpLev
8535 posts in 3641 days
#1 posted 01-01-2013 06:18 PM
that is a sweet deal!
I believe the old DCs were using 5 micron bags (Jet, Delta, etc). JDS came into the game later and might have started with 1 micron off the bat. with a 5 micron bag it would be fairly obvious as you’ll see a fine cloud of dust around the upper bag when in use if you put a light behind it.
I know it’s an extra expense, but I’d forgo the bags and get a canister for another $100. like the 220v and the 20amp circuits it’s money well spent.
Congratulations, and a Happy New Year!
Dusty56
#2 posted 01-01-2013 06:30 PM
Hi Sharon and Happy New Year to you and the family : )
My JET has the canister on it and I love it ! The replacement cost for it is over $300 however : (
Do you have a source for a 20 inch canister to fit the JDS for $100 ? I would buy it in a flash ! LOL
Thanks so much.
View sandhill's profile
sandhill
2128 posts in 3917 days
#3 posted 01-01-2013 07:06 PM
Good find Dusty, You bagged a great deal! The Bags are 5 micron bags at best and not enough to NOT ware a dust mask. I do not trust the bags. There are retro fits you can build for less then the cost of a new canister, which start at about $200.00 for one that would last.
View Roger's profile (online now)
Roger
20927 posts in 2797 days
#4 posted 01-01-2013 07:19 PM
You can buy a 1 micron bag on Amazon, or, somewhere to help even more.
View pintodeluxe's profile
pintodeluxe
5652 posts in 2806 days
#5 posted 01-01-2013 07:26 PM
You might check if Pioneer makes a paper filter for your model. I know for my Jet, they make a paper filter conversion kit with filter shaker for $80.
Dusty56
#6 posted 01-01-2013 07:27 PM
I’m going to give the company a call tomorrow to ask them about the original bag on this machine.
I went to WoodCraft yesterday for a new bottom bag(clear plastic) and they wanted over $30 for a 5 pack.
Glad I waited, just found them on Amazon for $13.71 / 5 : )
Thanks for the input guys : )
View Woodwrecker's profile
Woodwrecker
4148 posts in 3568 days
#7 posted 01-01-2013 08:23 PM
That looks exactly like my HF collector.
I fitted mine with a canister from Wynn (http://www.wynnenv.com/cartridge_filters.htm)
and it has worked out really great.
Definitely worth looking in to.
Nice deal you got by the way.
-- Eric, central Florida / Utor praemia operibus duris
PurpLev
#8 posted 01-01-2013 08:29 PM
wow, $30 for 5 plastic bags (I’m cheap… I empty mine into a contractor black trash bag when it’s full… still on my 1st and original bag).
I got my canister from Wynn Environmental as linked above by Woodwrecker. it totaled at $100-something to my door step. rated at 0.2micron – not bad compared to the jet huh?
the only drawback (and I haven’t seen the jet to compare) with the wynn canister is that it doesn’t have the beater to shake the dust off the canister. but you can either fabricate one, or just tap it all around to get it off (and you do want to keep some of the dust on it as it actually increases it’s filtration).
View DIYaholic's profile
DIYaholic
19618 posts in 2668 days
#9 posted 01-01-2013 08:38 PM
I was going to suggest Wynn Enviromental canisters, but alas, I’m a day late and a dollar short.
BTW: Nice CL Score!!!
Dusty56
#10 posted 01-01-2013 08:43 PM
Eric , that’s some great info there. Which filter did you go with ?
Did you buy any of their bottom bags ? 10 for $13….best price I’ve seen all day !
I still have the original bag on my JET , probably due to my separator , but I wouldn’t mind having a few spares kicking around just in case. WoodCraft wants over $30 for only 5 bags !
View Jonathan's profile
Jonathan
2608 posts in 3043 days
#11 posted 01-02-2013 02:46 PM
Wow, that’s a great CL score! One of these days I’m going to ante up for a Wynn for my Delta. I also simply empty my bottom bag out and re-use it.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View toolie's profile
toolie
2121 posts in 2621 days
#12 posted 01-02-2013 04:26 PM
great CL score dusty. +1 on a lower micron bag if the OEM bag is 5 micron or higher. also, consider this simple modification as it SIGNIFICANTLY improves the performance of units like yours:
http://lumberjocks.com/topics/40189
and when you want to automatically activate the DC when the tool to which it is attached is activated, try these guys. first rate products from a first rate company:
http://www.ivacswitch.com/index.action
BTW, you know the rule. no pics, didn’t happen. let’s see a few pics of your CL score.
Dusty56
#13 posted 01-03-2013 03:01 AM
It looks just like the one I posted above , minus the bottom bag , but has a metal hook rod that holds the top bag up for you. Same colors , same wording , same switch , casters , and dust hose connections : )
View crank49's profile
crank49
4030 posts in 2964 days
#14 posted 01-03-2013 04:09 AM
Yeah! you got a heck of a deal on a blue HF collector. The bag is 5 micron. the wynn cartridge will fit well.
Dusty56
#15 posted 01-03-2013 11:26 AM
LOL. thanks for the info , crank49 : )
