Ridgid Planer - Usage questions
Forum topic by Nick_R posted 169 days ago 406 views 0 times favorited 13 replies Add to Favorites Watch
View Nick_R's profile
Nick_R
77 posts in 347 days
169 days ago
Topic tags/keywords: planer advice tip how to ridgid
Hey Jocks! Need some advice regarding a planer and specifically its usage. What would you consider the minimum safe width of a board to put through a planer. I am using a ridgid 13” planer and have thought about putting 1”x1”x6’ through to create slats for benches but thought they might get askew and create problems.
Also… sounds dangerous so I would not try it but if it occurred to me it probably occurred to someone else. Would you ever put a board through on edge? Sort of like a jointer type operation?
Thanks in advance.. Happy New Year!
-- Hope for the best but plan for the worst. - 7 finger Nick :)
13 replies so far
View ShaneA's profile
ShaneA
4012 posts in 796 days
#1 posted 169 days ago
Should not be a problem to put a 1” square piece through.
View Don W's profile
Don W
10215 posts in 765 days
#2 posted 169 days ago
Not a problem. If I was doing it, I’d stack a bunch side by side just to save time.
If you do run them threw and they start to skew, just “help” them straight.
View Bagtown's profile
Bagtown
1637 posts in 1927 days
#3 posted 169 days ago
I’d do that. I’d probably feed a half dozen through at a time too.
-- http://www.heartofsackville.ca/
Don W
#4 posted 169 days ago
Beat ya bags….....
View cutworm's profile
cutworm
698 posts in 991 days
#5 posted 169 days ago
Sometimes the board I’m planing gets a little skewed but it doesn’t seem to hurt anything. At 6’ you may get a little snipe on the ends.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
Bagtown
#6 posted 169 days ago
View HorizontalMike's profile
HorizontalMike
5593 posts in 1111 days
#7 posted 169 days ago
I have planed on my Ridgid R4300, down to just 0.200in in thickness. As a matter of fact, I am not sure my adjustments allow me to go any thinner.
As far as width, I have turned 3/4in boards on their sides and run them through. Always better if you can run 2-3 of them side-by-side because that seems to plane better and at a 90* angle without much fuss.
View NormG's profile
NormG
2632 posts in 1201 days
#8 posted 169 days ago
I think everyone else has pretty much covered it all
-- Norman
View Purrmaster's profile
Purrmaster
406 posts in 290 days
#9 posted 169 days ago
I’ve run small pieces through the planer and I’ve never had a problem with it. If the pieces goes in at an angle or goes out at an angle, that’s fine.
View gfadvm's profile
gfadvm
6907 posts in 887 days
#10 posted 169 days ago
No danger planing narrow pieces at all. I intentionally skew some woods as it seems to help tearout problem. Tall/narrow pieces can be done (best to sandwich several together) as well. SHORT pieces are the dangerous ones. Stick them to a carrier board with some double faced tape or they’re liable to get caught between the rollers and explode! Don’t ask how I learned this.
ShaneA
#11 posted 169 days ago
where you will want to show caution is planing it down in the 1/4” thickness and lower. It can be done, but it can also get a little dicey, if its get chewed into chunks, you will have a problem…dont ask how I learned this. I also skew boards all the time. It will cut down on planer tracks and keep wear more even on the blades.
Just dont stand directly behind the infeed area of the planer, that is the “strike zone”. Dont ask me how I learned this either….lol.
Nick_R
#12 posted 169 days ago
Thanks Jocks! You are all great resources. Happy New Year
View pintodeluxe's profile
pintodeluxe
1851 posts in 1011 days
#13 posted 169 days ago
I run boards on edge through my planer quite often. It puts a great finish on edge joints – better than my jointer or tablesaw.
