| Forum topic by LeChuck | posted 145 days ago | 605 views | 0 times favorited | 13 replies | ![]() |
145 days ago |
Hi folks, Does anyone have experience with the #7 jointer planes that Grizzly sells, in particular their “smoother” one with the corrugated sole? It seems to get decent reviews on Amazon. As I am working on a base for my workbench and will soon have some work holding capability and a good surface to work on, I’d like to get a jointer plane and do away with some of the limitations of my 6” jointer. I was bidding on a nice Record on eBay but it went higher than I was ready to pay. In retrospect, I should probably have tried to get that one. Budget is limited and I cannot spend much, nor am I willing to restore a rust bucket at this point. I haven’t found anything worthwhile in the local antique shops and Craig’s List is not very prolific around here. I am not a collector and I’m just interested in something that works well. The Grizzly is pretty cheap, I’m wondering if it can simply do the job well. Thanks! -- David - Tucson, AZ |
13 replies so far
#1 posted 145 days ago |
I didn’t know Grizzly had hand planes. After looking at them I think you might Fellow LJer DonW can hook you up at: http://timetestedtools.wordpress.com Or, Veritas at: http://www.leevalley.com/US/Wood/page.aspx?cat=1&p=41182 Enjoy your journey, you’re going to dig it. |
#2 posted 145 days ago |
I am not sure on your budget. But it looks like you have not decided on which FIRST handplane you want to start with. I will go for a jack plane first. If the budget is below USD 100.00 then buy a used Stanley #5 and tune it up. Tuning will take time and effort….. I hear good things on WindRiver, LN and LV but it is well above 100.00. At any case start with wood stock |
#3 posted 145 days ago |
IF you mean Groz, instead of Grizzley….... Stay away from anything with GROZ on it. E Bay has a LOT of #5 Jack planes going for less than $30, counting shipping. -- A Planer? I'M the planer, this is what I use |
#4 posted 145 days ago |
With all the good used #7s out there, I wouldn’t buy one of those planes. They’re $55, and for about the same price you can get this one, for example. -- ian | "You can't stop what's coming. It ain't all waiting on you. That's vanity." |
#5 posted 145 days ago |
I’m sure the Grizzley will get the job done. Bench plane function is mostly about the basic geometry of In #4 sized planes meant for final smoothing of woods Nice planes are nice to have, but any jointer with |
#6 posted 145 days ago |
Thanks for the replies. I was mostly hoping for feedback from users of the Grizzly planes, but I’m of the opinion that most tools should just be able to get the job done, unless they have some definite big flaws. I probably did not give enough information, but to recenter the subject: I am not looking for my first plane. I have a #4 that is made by Anant, their “AA” premium line (the blue ones) and it has a nice 1/8 thick blade and works really well in my opinion. If they made a #7 like that, I’d try to get one of those. I also have a Craftsman 3732 low angle block plane, which is really a Stanley #65. I do need a jointer plane. My jointer is too narrow and too short, and I need to be able to do some hand flattening. I cannot afford anything remotely close to a Veritas, LN, or even WoodRiver. And I’m definitely not talking about Groz :) I did have a few Groz planes in the past. I still have one of their block planes too. -- David - Tucson, AZ |
#7 posted 145 days ago |
I have a Bailey #8 (@$25) I rehabbed last year, i have a bob-tailed KK7 that was also a rehab. I have TWO #6 small jointers , and a Union #5A that is a little smaller yet, All are about the same width in the cutter, from 2-5/8” for the #8, down to 2-1/4” for the one #6. The most they cost was that #8. -- A Planer? I'M the planer, this is what I use |
#8 posted 136 days ago |
Well, I ended up buying an older Record #7 on ebay for a decent price. Haven’t had time to test but the plane seems nice and is in pretty decent condish, except the blade, which is badly nicked in several spots. At this point, and with a tight budget and without owning a grinder, I’m wondering if it’s worth it to just spring for a new blade from Veritas (and perhaps a new chip breaker) or taking this thin-ish old blade to some sand paper to try to grind out the nicks and resharpen…I do have an 8” disc sander and a 1” belt… -- David - Tucson, AZ |
#9 posted 136 days ago |
The old blade will be fine. Even new blades need to be honed, and it’ll be good experience to regrind the bevel on the old one. And there’s nothing wrong with a thin blade. It’s easier to sharpen and hone, and properly set up will perform just as well. If you use a powered sander, make sure you use a light touch and don’t cook the blade. Keep a cup of water handy and dunk it when it gets hot. -- ian | "You can't stop what's coming. It ain't all waiting on you. That's vanity." |
#10 posted 136 days ago |
The disc sander should work to regrind the bevel and then you can sharpen and hone using a scary sharp method (if you don’t have sharpening stones). As shampeon mentioned, use water to keep from overheating the blade with the disc sander and you will be fine. The “thin-ish old blade” will work great, no need to replace it. -- "The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself." -- Benjamin Franklin |
#11 posted 136 days ago |
Thanks. Time is a bit tight right now, but because I could not order and receive a new blade before the weekend, I’ll just have to refurb the old blade so I can actually start using it, then we’ll see how it works I guess. My #4 plane has a 1/8 blade that seems to stay pretty sharp forever. I am building a workbench base and had to flatten one edge on 20 boards with the #4 as I took my power jointer back to Harbor Freight for a refund. The knots are terrible though. I have a 1000/4000 stone and a good guide so I should be good after the regrind. -- David - Tucson, AZ |
#12 posted 136 days ago |
If this info makes any difference, the stock blade on this Record plane is tungsten vanadium… -- David - Tucson, AZ |
#13 posted 136 days ago |
Correction, “tungsten steel”. -- David - Tucson, AZ |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
