| Forum topic by mnik | posted 143 days ago | 413 views | 0 times favorited | 9 replies | ![]() |
143 days ago |
Topic tags/keywords: jtas-10xl cabinet saw dust bottom There’s quite a lot of space on the on the sloped bottom of the new (to me) cabinet saw. I’d like to seal that space up to keep dust from falling on the floor. Here’s a photo: http://mnik.net/external/ts_bottom.jpg My first thought was silicone (stays put, easy to remove) but those corner spaces look a little big (up to 1/4”) to hold a bead. Second idea: foil tape, but those corners will be tricky to keep a crisp edge. I’m seeing something like the way our 7y/o wrapped his mom’s Xmas gift. Except I’m not 7 and this is my gift. -- Yeah, I'm probably over-thinking it. But that's my other hobby. |
9 replies so far
#1 posted 143 days ago |
White vinyl duct tape. Silicone caulk. Maybe even that spray foam that doesn’t I would probably use duct tape if there is room to apply it. |
#2 posted 143 days ago |
I used the foil tape, and didn’t worry too much about “crisp” corners. Like Ron said, this isn’t something someone will see. Mines been in there for over 4 years so far with no damage or problems. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#3 posted 143 days ago |
Use a backer board or dowel and then add silicone. |
#4 posted 143 days ago |
I would use foil tape as much as possible. I like the spray foam for the tricky places, like to seal off the table top cavities and cabinet. -- jay, www.allaboutastro.com |
#5 posted 143 days ago |
Try caulk backer rod…Inexpensive and is easy to use for many sealing tasks around the house. Comes in many sizes and compresses a lotto fit many applications. Tape and other things are sticky and hard to remove. https://www.dap.com/product_details.aspx?BrandID=4&SubcatID=1 -- Few folks really know how to maximize the potential of their tools! |
#6 posted 143 days ago |
Excellent. Turns out I have some backer rod already just waiting to be used. -- Yeah, I'm probably over-thinking it. But that's my other hobby. |
#7 posted 142 days ago |
I got some backer rod from ACE hdwe one time. It was 1/4” and looked and worked like modeling clay. I can see that working well if the other doesn’t. |
#8 posted 142 days ago |
Thx Grandpa. I’m glad you mentioned it, as the stuff I have is more like 1/2.” I purchased it for renovation on the 1872 house we bought a little over a year ago. Anyway, it was too big for the purpose I needed it for -filling in a 1/4” gap -so if I can find the stuff you mentioned I’ll be killing two birds. -- Yeah, I'm probably over-thinking it. But that's my other hobby. |
#9 posted 142 days ago |
I think I’d use the puddy Gpa mentions or the silicone and then the foil back tape. I have a large gab between my table saw cast iron top and the cabinet. I used Styrofoam to wedge in the gap and that really helped the HF Dust / Chip collector keep up with collecting the waste. I have a few rolls of the foil tape and hadn’t thought about using that > Hmmmmm I’ll look at that tomorrow!! There’s also a few openings in the bottom of the cabinet I can use that for!! Thanks and hope it works for you. Ant -- Ant |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
