wooden gate arch
Forum topic by scottishbob posted 12-31-2012 04:25 PM 4248 views 0 times favorited 4 replies Add to Favorites Watch
View scottishbob's profile
scottishbob
171 posts in 2406 days
12-31-2012 04:25 PM
Topic tags/keywords: gate
Hi lads
Need a bit of help here ! this is a pic of a gate that i would like to make for my driveway http://www.agdsystems.co.uk/UserFiles/Image/Timber%20swing%20gates/Cambridge-1.jpg
Now my drive way entrance is 14ft wide with 4ft high stone pillars each side , so i will be making 2 timber gates, appox 4ft x 7ft, in , now i am wondering how to go about making an arched brace , it is a large arch so how is it constructed? going on the pic i dont think its laminated using thin strips
Thanks Bob
-- Ireland, Galway .... fingers! "we dont sell them"
View oluf's profile
oluf
260 posts in 3158 days
#1 posted 12-31-2012 08:39 PM
Band saw cut them out of a glue up. Use epoxy for your glue ups. Glue short pieces to a long piece to give you the size you need for the total shape, You could also band saw them out of plywood and bend a thin strip for edge banding so it would look like solid wood. It is a very nice looking gate.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View BTimmons's profile
BTimmons
2303 posts in 2604 days
#2 posted 12-31-2012 09:13 PM
Take a look at the left arch and the lamination pattern should be obvious. It’s constructed of the wide faces of board. I’ve done a crude MS paint dissection. The light and dark regions are a dead giveaway.
-- Brian Timmons - http://www.BigTWoodworks.com
404 - Not Found
2544 posts in 3088 days
#3 posted 12-31-2012 11:31 PM
Make it bigger and you’ll have room to work it.
If I was doing this job I’d make a template and do the final shaping with a router using a 1/2” x 2” worktop trimming bit.
Cheers.
scottishbob
#4 posted 01-01-2013 07:33 PM
thanks guys
