Any tips on removing ink?
Forum topic by abkma posted 93 days ago 129 views 0 times favorited 7 replies Add to Favorites
View abkma's profile
abkma
11 posts in 104 days
93 days ago
Topic tags/keywords: ink removal oak poly polyurethane
Hi all,
My youngest son created some artwork for us. The only problem is that he drew it all over the cupboards. They are oak finished with Polyurethane. Anyone have any tips or ideas that I can try to remove the ink without ruining the finish.
Thank you so much,
2078 posts in 558 days
93 days ago
Didi 7 is pretty good. It will depend on what the “ink” is too.
If your surface was penentrated during the tagging you may have more problems.
View Praki's profile
Praki
86 posts in 533 days
93 days ago
I have used toothpaste with success. The only caveat is the surface I cleaned was laminate.
-- Praki, Aspiring Woodworker
abkma
93 days ago
Bob #2 – Thanks for the link. It’s a cheap ball point pen. It’s barely visible so I think I might have lucked out as far as penetration.
View jimp's profile
jimp
45 posts in 297 days
93 days ago
I don’t know if these will work on your cupboards, but Mr. Clean Magic Eraser do a great job removing markers and crayons for walls.
Good luck.
View Doug S.'s profile
Doug S.
217 posts in 244 days
92 days ago
Try denatured alcohol (just not over shellac). It usually disolves ballpoint pen type ink.
-- Use the fence Luke
View John Gray's profile
John Gray
882 posts in 422 days
92 days ago
Hair spray….try it on a not to visible area too see if it effects you finish 1st. My 2 cents.
abkma
85 days ago
Hi all,
I want to thank everyone who responded to my post. It truly is great to be able to put something like this out there and receive so many knowledgeable replies.
For anyone that is interested my wife purchased one of the “magic erasers” at the grocery store this morning and it took everything right off. The only damage is one small spot where the wood was dented by the pen, but the ink even came out of that.
Now I’m off to install a latch on one of our drawers for all of the pens. Thanks again.
Bookmark And Share This Page
