I need a chuck for a Jet 15 inch floor drill press
Forum topic by Jeff_in_LSMO posted 12-31-2012 02:45 PM 1046 views 0 times favorited 6 replies Add to Favorites Watch
View Jeff_in_LSMO's profile
Jeff_in_LSMO
347 posts in 2247 days
12-31-2012 02:45 PM
Topic tags/keywords: jet jdp-15mf jet drill press
I could write a review, but I won’t. Let’s just say that I am generally unhappy with this drill press and I lack the permission to get something better.
That being said, the chuck has to go. It is a total piece of crap. No matter how hard you tighten it, the thing will not hold a bit secure. I have had numerous instances of a bit slipping, which is very frustrating.
Does anyone have a suggestion for a replacement chuck? Jet JDP-15MF 3/4hp.
View Bill White's profile
Bill White
4859 posts in 3867 days
#1 posted 12-31-2012 03:13 PM
Jacobs chucks are the standard of excellence as far as I know, but there are some pretty good clones available.
Just be sure to get the correct taper.
Bill
-- bill@magraphics.us
View sprucegum's profile
sprucegum
324 posts in 1904 days
#2 posted 12-31-2012 03:38 PM
Last year I purchased a beast of a drill & mill at auction the chuck was a old Jacobs that had seen a pipe wrench a few too many times. I purchased a 3/4” made in china on ebay for around $25 (don’t recall the exact price but that is close). It came with a #2 morse and a R-8 taper. I am very pleased holds well and runs true. It will not grip drills 1/8” or smaller but I expect that is because it is a really big chuck. I have a 3/8 chuck also made in china that I use for small drills.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View Grandpa's profile
Grandpa
3259 posts in 2582 days
#3 posted 12-31-2012 05:12 PM
Chucks do have a minimum drill size. Use a micro chuck in the big chuck and put the small drills in the mico chuck. I have a 5/8 Tiawan chuck on my press and it stops holdin when you get smaller than 1/8. this was my cure.
View Lee Barker's profile
Lee Barker
2170 posts in 2757 days
#4 posted 12-31-2012 05:18 PM
Chucks have a life. A machinist once told me that they would change every chuck in the shop, once a year.
Are there other issues with the tool that could be addressed? A drill press is a pretty simple piece of machinery, and generally not a source of frustration. I bet the collective wisdom of LJ could help you turn it into a sweetheart tool, with very little expenditure.
Kindly,
Jeff_in_LSMO
#5 posted 12-31-2012 07:11 PM
Lee, other than the cheapest key money could buy, which really ircks me, the chuck is my main source of frustration. I probably only have 4 – 5 hours of run time on it since I purchased the drill new that past summer.
And it doesn’t seem to be dependent on shank diameter. I’ve had bits spin from 1/8” up to 1/2” in the middle of a hole. Not always, but my dad’s old Craftsman never did this.
I’m just really annoyed to the point of purchasing an aftermarket chuck. Thoughts?
View NiteWalker's profile
NiteWalker
2736 posts in 2484 days
#6 posted 12-31-2012 07:17 PM
You may have just gotten a lemon chuck. Contact Jet and see if they’ll send you a new one. Their 15” press is a good one.
