DIY Branding Irons?
Forum topic by Sam posted 12-31-2012 12:10 AM 17176 views 2 times favorited 25 replies Add to Favorites Watch
View Sam's profile
Sam
30 posts in 2325 days
12-31-2012 12:10 AM
Topic tags/keywords: diy brand branding iron marking wood burn burning sign custom brass letter
I’d had the notion to fashion my own branding iron for my projects. Anyone else attempted/accomplished this? If so, did you go with a design or legible text? I’ve seen the hobby-irons with brass letters, but just curious if anyone else has thought of an alternative to the $80 custom-made irons.
Thanks!
-- -Sam
25 replies so far
View Sam's profile
Sam
#1 posted 01-01-2013 01:47 AM
Wow… 117 views, but no replies. :( Hmm… guess this isn’t a common idea?
-- -Sam
View Don W's profile
Don W
18686 posts in 2537 days
#2 posted 01-01-2013 01:53 AM
I’ve got nothing. I’ve seen this question posted before. Most got about the same response as yours if memory serves me right.. I found a branding iron with initials (DE if I remember correctly). I always wondered if I could re-cut but its never made it to the top of my list.
View Stephenw's profile
Stephenw
273 posts in 2355 days
#3 posted 01-01-2013 01:56 AM
It could be done. Engrave your design into a chunk of copper or brass. Perhaps carbide burrs in a Dremel tool to do the engraving. Attach your custom “brand” to an old heavy duty soldering iron…
View Sam's profile
Sam
#4 posted 01-01-2013 05:38 AM
Thanks Stephenw, that’s an interesting idea.
-- -Sam
View prattman's profile
prattman
445 posts in 2087 days
#5 posted 01-01-2013 10:07 AM
Hey Sam, I got a branding iron for Christmas and when I posted my first branded board ,SawSucker commented that he had made his own brand. He didn’t give any details but if you look him up he might be able to help.
-- Everyone calls me Ed or Eddie , mom still calls me Edward if she is mad at me.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2826 days
#6 posted 01-01-2013 10:21 AM
Sam, I use a branding iron but also use rubber stamps
for some of my customers own logos. Once oiled it also looks
great and for $5 including artwork you cant go wrong. It also
gives you a chance to try different designs.
Alternately if you look on woodgears he has a pantograph that
you could use a dremel on and engrave a block of brass. Great thing
about this way is you do the large artwork in plywood then when the
pantograph reduces it you have a very neat looking design.
He also has a font generator that can do mirror image.
Would like to see how you go with it.
Jamie
Edit. http://woodgears.ca/pantograph/index.html
http://www.ebay.co.uk/itm/Personalized-Mounted-Custom-Rubber-Stamp-Return-Address-/260793282223?pt=LH_DefaultDomain_0&hash=item3cb87daeaf
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View History's profile
History
399 posts in 1951 days
#7 posted 01-01-2013 11:58 AM
Yep, I made a branding iron. I used steel, and it has my initials.
View mtenterprises's profile
mtenterprises
933 posts in 2662 days
#8 posted 01-01-2013 01:22 PM
I made my own branding iron many many years ago from a 3/8” square head bolt. I used my Dremel tool with abrasive wheels to cut away what I didn’t want. I epoxied it into a wooden handle I had lying around and I heat it up with the propane tourch or on the gas stove. It ain’t perfect but I use it anyways. It was one of my first metalworking projects. Today I’d just put a chunk of steel on the mill and have at it, that was then this is now.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
Jamie Speirs
#9 posted 01-01-2013 01:33 PM
Mike I prefer your one to my precision made one
It is hand crafted for hand crafted pieces
Jamie
mtenterprises
#10 posted 01-01-2013 01:44 PM
Jamie, thanks for your compliment.
My only problem with it is it’s a bit too big for some of the projects I do now so I just sign them with a ultra fine Sharpie and cover it with Minwax water base polycrylic before my regular finish. Sharpies are solvent based so it has to be covered by a water base clear coat first or it will bleed.
MIKE
Jamie Speirs
#11 posted 01-01-2013 02:14 PM
Mike, time to make a wee one then?
When I use inks I give them a wee dab of
finish normally Danish oil, I dont rub though, I’ve
smudged a fair few in the past. :( Normally a rush
order to boot.
jamie
View tyskkvinna's profile
tyskkvinna
1310 posts in 2955 days
#12 posted 01-01-2013 02:51 PM
I’ve made several for my work. At one point I did custom orders of them in my Etsy shop, perhaps I should do that again.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View mdennisusa1's profile
mdennisusa1
38 posts in 2123 days
#13 posted 10-31-2013 07:45 PM
I’m wondering if a guy could use a Dremel tool and a diamond bit to carve around a deisign on a block of brass to make a simple branding iron or signature block. Has anyone tried this? Once the snow hits and I have time to spend in the shop I give this a try and report back.
mtenterprises
#14 posted 11-01-2013 12:04 PM
Yes, basically what I did.
MIKE
View hydro's profile
hydro
208 posts in 1721 days
#15 posted 11-01-2013 12:53 PM
I have made several branding irons, using multiple techniques. They are simple in the concept, heated with a torch, and all utilize a steel block to act as a base for the design and to work as a heat sink.
Technique #1- Make your design out of thin strips of steel or stainless steel (be sure to reverse it) and then braze them to the base block. The strips should be a minimum of 20 gauge, and about 3/16 high to be easy to work.
Technique #2- Make the design out of 1/8” thick copper, brazed to the base block as above. Here you need to create the design and reverse it in your software, then print it. Glue the printed design to the copper stock and cut it out using a jeweler’s saw. Be sure to plan some webbing if there are design elements that will be separate in the brand. Braze it to the base and last, carve away the webs using a Dremel or similar tool.
With these techniques (and some welding skill) you can make all sorts of branding irons!
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
