Should I take the motor case off and blow it out?
Forum topic by mnik posted 12-30-2012 08:14 PM 874 views 0 times favorited 4 replies Add to Favorites Watch
View mnik's profile
mnik
58 posts in 2527 days
12-30-2012 08:14 PM
Topic tags/keywords: jet jtas-10xl maintenance motor
Bought a Jet JTAS-10XL off CG and while it’s in nice shape it was not cared for.
So while I’m cleaning it should I remove the motor case and blow it out or will compressed air just push dust into places it shouldn’t be?
I probably wouldn’t bother except for seeing reports like this: http://goo.gl/NJWBi on this saw.
-- Yeah, I'm probably over-thinking it. But that's my other hobby.
View Dan Krager's profile
Dan Krager
3999 posts in 2229 days
#1 posted 01-01-2013 07:40 PM
I would blow it out without hesitation using a relatively low pressure, say 60 PSI or so, with a fairly large nozzle. If it is a sealed case, that is not necessary, but the report makes it sound like the case leaks like a screen door on a submarine. If you do take it apart to clean it, consider how to tighten it up completely, perhaps with silicone, to prevent having to take it apart every year to clean it. Identify airways for cooling and be sure they are clear of debris.
I blow off my TEFC motors fairly often and have had no adverse effects.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View mnik's profile
mnik
#2 posted 01-01-2013 07:57 PM
Thank you Dan. Think I’ll enlist my pal who knows a lot more about motors when I do it as it sounds like the motor is unique to the manufacturer and I’d kick myself if I created a new problem. That’s one reason to buy a Unisaw: wide parts availability. That said, don’t think I’d find one for $600 in my area -and certainly not as in as good a shape as this one.
I’ll wait until I get the 220 line installed (hopefully in the next few days) and see how she runs first. There were some missing set screws in the arbor pulley. After I blow out the motor I then have to figure out where the table shim goes. The one that I didn’t note when I removed the table for transport during the purchase.
One problem at a time, right?
Appreciate your advice.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#3 posted 01-01-2013 08:24 PM
http://www.ereplacementparts.com/jet-jtas10xl-708662rxk-left-tilting-arbor-saw-parts-c-32652_32759_155017.html
HTH
Maybe print out a copy for yourself and congrats on your new to you saw!
View MonteCristo's profile
MonteCristo
2099 posts in 2183 days
#4 posted 01-01-2013 11:28 PM
Blowing it out will likely help, but if it’s a crappy motor, the dust will likely do it in anyhow. Totally Enclosed Fan Cooled (TEFC) motors are expensive, but they are up to the job . . .
