| Forum topic by cabinetmaster | posted 93 days ago | 279 views | 0 times favorited | 6 replies | ![]() |
93 days ago |
93 days ago |
Thanks for the post I’m inrterested in making a steamer too. -- Only the Shadow knows.................... |
93 days ago |
I found a site that talked about it. It was basically a hot plate a old metal gas can (well cleaned) and a hose. You then run the hose to a hole in a piece of PVC pipe. and put caps on the pipe. Loose not glued. A drip hole at the end of the cap. Lee Valley sells a little book on bending I was considering, but my bending project is on hold |
93 days ago |
woodworkforums -- Alejandro Moreno, CANARY ISLANDS |
93 days ago |
I use a 10” dia., galvanized piece of ducting with a removable cap on each end. By cutting slots in the side along its length I can “sticker” the steamed wood to permit steam around all the pieces. A 1 1/2” piece of PVC pipe goes from electric kettle to pipe |
92 days ago |
Thanks everyone for the posts. Alejandro, I would apprecite the information and I will look at the site you mentioned. Thanks again…............Jerry -- A man can never have enough tools |
82 days ago |
My setup is just a section of 6” PVC drain pipe with a cap on one end and a threaded drain cleanout plug on the other. A hole is drilled into it near one end and a radiator hose is attached from that hole to a gas can (brand new—never had gas in it). Put water in the gas can and heat it with a coleman stove or hotplate. -- Go STARS! |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1362 |
| Become a sponsor |
1807 |
| Become a sponsor |
123 |
| Become a sponsor |
377 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1019 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
