Mahogany substitute
Forum topic by WoodCop posted 12-29-2012 11:17 PM 1696 views 0 times favorited 9 replies Add to Favorites Watch
View WoodCop's profile
WoodCop
29 posts in 2147 days
12-29-2012 11:17 PM
Topic tags/keywords: mahogany
Hi all,
I am making a cabinet for my buddy to match his bedroom set, which is mahogany. Due to the cost, which he is trying to keep down, what would be a good substitute. We need to stain the wood ebony or black to match the set. Thanks!
-- “Things may come to those who wait...but only the things left by those who hustle.”
9 replies so far
View Wdwerker's profile
Wdwerker
333 posts in 2140 days
#1 posted 12-30-2012 12:44 AM
Might as well make it out of poplar. It will take stain quite well and is very affordable. Plus poplar comes in wide planks and usually several thicknesses.
-- Fine Custom Woodwork since 1978
View shampeon's profile
shampeon
1775 posts in 2090 days
#2 posted 12-30-2012 01:52 AM
Meranti is also known as Philippine mahogany, has similar grain and texture, and is usually much less expensive. African mahogany (khaya, sipo, or sapele) is also quite similar, is usually a bit harder than meranti, and is a bit cheaper than Honduran mahogany.
But as wdwerker points out, if you’re just going to stain it all ebony, you might as well use poplar or alder if it’s not important to match the grain. Poplar or alder are closed-pore woods, so they’ll appear smooth, while meranti or African mahogany have open-pores like real mahogany.
View MonteCristo's profile
MonteCristo
2099 posts in 2095 days
#3 posted 12-30-2012 03:25 AM
I would think Honduran mahogany would be expensive, as it is a true mahogany. Some guys I know are using sapele.
shampeon
#4 posted 12-30-2012 05:55 AM
MonteCristo: right, that’s what I meant. At the hardwood dealer I use, meranti is about half the price of Honduran mahogany, and khaya/sipo/sapele is in between the two.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2892 days
#5 posted 12-30-2012 05:56 AM
I agree if you are staining it to consider poplar.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View WDHLT15's profile
WDHLT15
1722 posts in 2382 days
#6 posted 12-30-2012 01:25 PM
Sweetgum. It has spiral grain like mahogany, and cut on the quarter, you can even get some of the ribbon stripe that is so characteristic of mahogany. it is not as stable as mahogany, though.
View Jerry's profile
Jerry
221 posts in 3445 days
#7 posted 12-30-2012 02:23 PM
Is Lyptus available in your area. I have used it in place of Mahogany and I was buying it for $3.50bf in Minnesota
-- Jerry - Rochester, MN *Whether you think you can or you can't, you are probably right* - Henry Ford
WoodCop
#8 posted 12-31-2012 06:24 PM
I think for the sake of $$ and ease of use, I will go with the poplar. It’s pretty abundant in NJ, thanks all!
WDHLT15
#9 posted 01-01-2013 03:24 AM
Lyptus would be a good choice to match mahogany.
