Belt Sander Sharpeners -- What is Best Grit?
Forum topic by HorizontalMike posted 12-29-2012 10:57 PM 8709 views 2 times favorited 30 replies Add to Favorites Watch
View HorizontalMike's profile
HorizontalMike
7770 posts in 3115 days
12-29-2012 10:57 PM
Topic tags/keywords: polish buffing belt sander sharpening tool
The title pretty much says it all. I have recently ordered an HF sander that I will be converting into a sharpening jig for lathe tools and (maybe) hand planes. I am doing well with manual sharpening with my hand planes at the moment, so I may or may not use this sanding belt sharpening system on my hand planes, but want to explore the possibilities.
Combination 4in x 36in Belt/6in Disc Sander, upon which I hope to perform the following conversion… “page 20 Belt-Sharpening System – Build your own effective belt-sharpening sysem at a reasonable cost. Jim Echter” in American Woodturner, December 2012.
NOT interested in being chastised for not getting a “grinder”. I want to hear from those who actually use belt sander sharpeners. What grit do you use most often? And what grit of polish for your honing/buffing wheel?
30 replies so far
View Cliff De Witt 's profile
Cliff De Witt
130 posts in 2893 days
#1 posted 12-29-2012 11:17 PM
I just built one of these last week. with a 120 grit belt I get the best edge I have ever gotten I have a feeling that the wheels will just sit there till something needs to be reformed.
Once I got done with the modifications from American woodturner I went back and looked at Captain Eddie’s youtube #122A and B.
I wound up with his version and I LOVE IT!
120 is the smallest grit I could find so I now have the 80 grit that came with the machine and the 120 I bought.
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
View Stephenw's profile
Stephenw
273 posts in 2586 days
#2 posted 12-29-2012 11:34 PM
I use a Worksharp 3000, so I have no specific advice about which belt to use.
I have a 6×48 belt sander that I have used to sharpen things like shovel points, lawn mower blades, and gasket scrapers.
I wanted to mention that I have seen 4×36 belts as fine as 320 grit. Check at an industrial supplier.
View David Kirtley's profile
David Kirtley
1286 posts in 3199 days
#3 posted 12-30-2012 12:10 AM
I have 80 grit and 220 grit belts that I use.
For plane irons it would be too aggressive except for really rough shaping.
HorizontalMike
#4 posted 12-30-2012 01:11 AM
This is good information. I have been exploring the available grits and have found 60, 80, 120, 220, 320, and 600 grit in the 4in x 36in belts. Obviously the lower grits are cheaper, but I hope to avoid buying what I do not need.
My best guess (since all is in transit from just being ordered) is that 80-120 is good for “setting the angle” and that 220-320 for cleaning up the edge before honing. While I use 600 grit manually for sharpening my HP blades, 600 grit may not be as effective on a powered “belt” system?
David Kirtley
#5 posted 12-30-2012 01:36 AM
The belts will actually leave a finer surface than the grit size would indicate. You are moving a lot of abrasive material past quickly.
600 grit seems awfully coarse for a hand plane. They will cut much more sweetly if you bump that up to 1200-2000 grit.
I don’t know about the size you need for yours but you can also get leather belts to fit some sanders for getting serious with some fine polishing.
View bandit571's profile
bandit571
21761 posts in 2884 days
#6 posted 12-30-2012 01:54 AM
I never throw away a sanding beltIF it is still in one piece. The more worn, the better i like them for sharpening. The coarser ones I’ll use for things like flattening a plane’s sole and sides. IF the irons are really bad, then they go on there as well. I use the honig guide to keep a consistant angle while on the sander. Then, when i move to the stones, I keep the guide in place.
Backs of irons and chisels: Also get the coarser grits, until they are flat, then I can start to polish the backs from there. it does no good to polish a back that is no flat.
Cambered irons: One of the easiest ways to camber an iron is on the beltsander. just take a circular track as you go from side to side, almost a figure eight. A cambered edge while result. By watching how big a figure eight you make, determines how much camber you make.
Anything else, Sir Mike?
HorizontalMike
#7 posted 12-30-2012 01:55 AM
-’...600 grit seems awfully coarse for a hand plane. They will cut much more sweetly if you bump that up to 1200-2000 grit….”_
Yeah, that is probably why I will stay with manual sharpening of my HP blades. I go to 600 grit and then jump to my 8000 stone to finish these plane blades. I know I am probably working harder by doing it this way, but it sure seems much easier to keep them sharp after the first time, for sure. I never let them get get very far away from sharp, if you know what I mean.
One of my bigger goals for this belt sander conversion is to have a decent buffing wheel set up, and there I do plan on honing my HP blades if all works out as planned.
HorizontalMike
#8 posted 12-30-2012 02:32 AM
Thanks for the technique tip Bandit. It sure will be nice once I actually get hands on with this stuff. I hate having to visualize something I have yet to do for the first time.
So what would be a good starting stock of belts? A 5-pak?, a 10-pak? and of what grits to start with?
bandit571
#9 posted 12-30-2012 03:01 AM
Just walk in, and grab a handful of the cheapest singles the store has. One of each grit. Try each out, and take notes on each. When you find a winner in the crowd, go back and get a pack of them, and the secnd place as well. Why the cheapest belts? Save your money, and get a dang good honing guide. Either one of the Veritas are good. i happen to have the MK1. No coarser than 100 grit. Any coarser is a waste of time, and belts. You’ll spend too much time getting rid of them scratches a coarse belt leaves. 100 grit, and go out and hog down some rough sawn lumber with it first, just to “break them in”.
David Kirtley
#10 posted 12-30-2012 04:03 AM
Actually, if you mount some leather on the wheel, it would make a nice one stop sharpening station for most stuff.
HorizontalMike
#11 posted 12-30-2012 11:20 AM
Bandit,,
I have a Honing Guide, but as nice at the Veritas. As far as not going TOO coarse with grit… That is what I was wondering, PLUS what grit is TOO fine? 320? 600?
David,
Here is what the converted sander should look like. It calls for the addition of a buffing wheel, though I did wonder if putting leather on the existing wheel would be doable as an alternative.
V—AFTER Conversion—V (*American Woodturner Dec. 2012)
V—BEFORE Conversion—V
View b2rtch's profile
b2rtch
4867 posts in 3249 days
#12 posted 12-30-2012 01:26 PM
Mike, I must be stupid but I do not understand how to use this sander to sharpen turning chisels.
IMO the best place for any kind of abrasive is Klingspor
http://www.klingspor.com/products/index.htm
-- Bert
View waho6o9's profile (online now)
waho6o9
8519 posts in 2777 days
#13 posted 12-30-2012 01:36 PM
HorizontalMike
#14 posted 12-30-2012 02:06 PM
Harbor Freight Belt Sharpening System in action (*American Woodturner Dec. 2012)
b2rtch
#15 posted 12-30-2012 02:42 PM
Thank you Mike and waho6o9.
Happy New Year to you and to your loved ones.
-- Bert
showing 1 through 15 of 30 replies
