"Big" Bowl Bottoms
« back to Woodturning forum
Forum topic by Dustyjosh posted 12-29-2012 08:58 PM 1189 views 0 times favorited 8 replies Add to Favorites Watch
View Dustyjosh's profile
Dustyjosh
5 posts in 2035 days
12-29-2012 08:58 PM
Topic tags/keywords: turning big bowls finishing work large chuck jumbo jaws
Hello friends! Thanks again for the advice on chucks. Ended up with PSI beginner one and its working just great. Today’s question is about finishing the bottom of a big bowl 10”-16” in diameter. When i an working on a smaller diameter bowl 4-8” after separating the bowl from the tenon I simply turn it around and grab with PSI Jumbo Jaws and clean up/sand the bottom. How can I do the same thing with a much larger bowl? Homemade holder? Other thoughts. As always I am grateful for you insights. Best, dustyjosh
8 replies so far
View Wildwood's profile
Wildwood
2322 posts in 2159 days
#1 posted 12-29-2012 09:15 PM
Ever heard of a jam chuck or donut chuck?
Check out chucks at: http://www.woodturningonline.com/Turning/Turning_articles.php?catid=9
-- Bill
View lew's profile
lew
12102 posts in 3780 days
#2 posted 12-29-2012 09:49 PM
I like to use one of these-
http://www.woodworkersguide.com/2010/10/17/how-to-make-a-longworth-chuck/
View mpax356's profile
mpax356
72 posts in 2517 days
#3 posted 12-29-2012 10:42 PM
I showed more than one way to handle this in my video you can link to from this thread http://lumberjocks.com/topics/44404
-- MPax, Atlanta
View MonteCristo's profile
MonteCristo
2099 posts in 2213 days
#4 posted 12-30-2012 03:30 AM
A vacuum chuck with a big drum is expensive but solves this problem (and many others !).
View RVroman's profile
RVroman
163 posts in 2048 days
#5 posted 12-30-2012 03:43 AM
For bigger bowls an “internal tenon” (not sure what the correct terminology for this is) works well. That way once you finish the outside and turn it around you never have to reverse it.
-- Robert --- making toothpicks one 3x3x12 blank at a time!
View tamboti's profile
tamboti
207 posts in 3166 days
#6 posted 12-30-2012 08:22 AM
Hi Look at projects and look for longworth chuck made by quatersawn this will solve your problem regards Tambotie
-- Africa is not for sissies
View ldl's profile
ldl
1135 posts in 2390 days
#7 posted 01-01-2013 03:53 PM
Does the longworth chuck do good from the inside on bowls that are tapered in from the top.
-- Dewayne in Bainbridge, Ga. - - No one can make you mad. Only you decide when you get mad - -
View JollyGreen67's profile
JollyGreen67
1676 posts in 2787 days
#8 posted 01-01-2013 06:11 PM
Longworth chucks: Whenever the chuck is expanded / contracted use nylon lock nuts on the back. I have found, when the chuck is in operation it will slowly expand, due to centifigul force, and the object being turned will come loose. After you adjust the chuck for use, tighten the lock nuts and all will be ok.
Dewayne: The longworth will work in expansion mode also. See above.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
