hand drill primer
« back to Hand Tools forum
Forum topic by Carpintero posted 12-28-2012 11:11 PM 1071 views 0 times favorited 6 replies Add to Favorites Watch
View Carpintero's profile
Carpintero
16 posts in 2101 days
12-28-2012 11:11 PM
I’m looking for a hand drill/bit brace primer. How to use, techniques for different materials/goals, types of bits, etc. I ordered a copy of Watson’s Hand Tools: Their Ways and Workings. Maybe that will cover what I’m looking for, I dunno.
View sikrap's profile
sikrap
1121 posts in 3261 days
#1 posted 12-29-2012 03:25 PM
There is someone on ebay selling reprints of some of the old Stanley instructional posters and there is one on hand drills. This should be a link http://www.ebay.com/itm/Vintage-STANLEY-TOOLS-Educational-WOODWORKING-POSTER-Chart-HAND-DRILL-Auger-Bits-/290834830925?pt=LH_DefaultDomain_0&hash=item43b71b564d
-- Dave, Colonie, NY
View Brad's profile
1139 posts in 2642 days
#2 posted 12-30-2012 02:58 AM
This series includes restoration techniques. If you just want use info, skip to the latter parts. But every single entry is worth the read. Andy covers the ground quite well. So far, it’s been the only series I’ve needed to make very decent holes.
-- "People's lives are their own rewards or punishments."
Carpintero
#3 posted 12-30-2012 06:08 AM
Whoaaaa….that wasn’t a primer, it was a dissertation! I already learned more in 5 minutes than I knew in 50 years.
Carpintero
#4 posted 01-06-2013 09:26 PM
So, I always see auger bits mentioned in conjunction with bit braces. Why is that? Should I not use other types like spade bits or Forstner bits for example? (cuz I’ve done both, and hope I don’t get kicked out of Lumberjocks for it) Or is the auger simply the most eh…politically and historically correct?
View knockknock's profile
knockknock
439 posts in 2075 days
#5 posted 01-07-2013 01:41 AM
Braces are slow speed drills with a fair amount of torque. The auger bits made for braces (not high speed augers), have a screw point to pull the the bit into the wood. Side cutters for the sides of the hole, blades to hog out the bulk of the hole, and a cork screw to lift the chips out of the hole. This design of the bits enable the slow speed brace to drill a hole as fast as a higher speed drill.
Carpintero
#6 posted 01-07-2013 04:35 AM
ah-hah! I knew there had to be a reason. I had not done any speed tests, but now I will. :-)
