| Forum topic by woodengaragedoorguy | posted 145 days ago | 446 views | 0 times favorited | 8 replies | ![]() |
145 days ago |
I put a nice sized bead of exterior wood glue to the garage door frame, trowel it, then apply tongue and groove material piece after piece. I use 1-1/4” divergent staples which work great for holding power. Most of the tongue and groove lays pretty flat to the garage door frame but I have noticed that when I start using tongue and groove wider than 6” I sometimes see that material cupping slightly. Note* these materials are glued up with 2 glue lines (3 pcs total making that one piece of TGV). I know I could screw the center of each piece and then use a wood plug to fill then sand smooth. But does anyone have any tips on a type of glue, or fastener method to where I could get these materials flush and have less cupping? All wood that I use is below 10%. |
