band saw with cast iron trunnion or without?
Forum topic by shelly_b posted 12-28-2012 03:49 AM 3900 views 0 times favorited 22 replies Add to Favorites Watch
View shelly_b's profile
shelly_b
850 posts in 2022 days
12-28-2012 03:49 AM
I am looking at buying a bandsaw soon. I got some xmas money that I plan to use to get a grizzly 17in but I don’t know if I should pay $850 and get the one without the CI trunion or $1050 and get the one with. The one without is on sale right now so will probably go back up to $950 soon. I really have no idea what having a CI trunion even means. Should I go with or without?
22 replies so far
View Loren's profile
9948 posts in 3553 days
#1 posted 12-28-2012 04:12 AM
Other differences in the saws you are considering are
in what the wheels are made of (cast iron in the
higher priced one) and the way the blade guides
are made.
Probably the lower priced saw has a pot metal
trunnion and wheels. The wheels will have less
mass and so forth. Pot metal isn’t bad for wheels
and band saw trunnions especially, but cast
iron has more vibration-dampening mass and
can take harder use. For a small shop the
durability of the metal is not likely to be a factor
for you. My guess would be that the saw
with the iron parts probably runs with less
obvious vibration.
View MonteCristo's profile
MonteCristo
2099 posts in 2093 days
#2 posted 12-28-2012 04:35 AM
I think it would be worth comparing the two saws closely to see what other differences there are. Also, if the trunnions aren’t cast iron, what are they ? Things like the quality of the blade guides and the wheels, as well as the motor are every bit as important, if not more so.
shelly_b
#3 posted 12-28-2012 04:49 AM
They are both 2 HP. The other wheels are cast aluminum. •Blade guides: Euro-style roller disc with full enclosure protection. The table is 5in longer, the fence is CI instead of extruded aluminum, guides are ball bearing instead of roller disc, cast iron wheels vs cast aluminum.
What is the trunion?
shelly_b
#4 posted 12-28-2012 04:50 AM
I didn’t realized the blade guides were different. I really wanted the wheels
View JesseTutt's profile
JesseTutt
853 posts in 2015 days
#5 posted 12-28-2012 04:52 AM
I have the grizzly 17” X2BF model and I love it. It has the cast iron wheels, bearing blade guides, cast iron trunnion and a magnetic switch (if the power fails the machine is shut off when the power comes back on).
I would defiantly recommend the more expensive version. Whether you want to have a foot break is your choice. I find that finding the break petal while keeping my eyes on the work is difficult. In an emergency I can’t imagine using the foot break.
13594 posts in 3246 days
#6 posted 12-28-2012 04:55 AM
waiting for glue to dry here
just looked at them both
the http://www.grizzly.com/products/17-Bandsaw-2HP-w-Cast-Iron-Trunnion/G0513X2
has better guides
cast iron wheels
better fence (and taller for re-sawing)
i’d go with it myself
thanks for letting me spend your money
even virtually lol
View Straightbowed's profile
Straightbowed
717 posts in 2203 days
#7 posted 12-28-2012 04:58 AM
go with the cast iron or you can upgrade later they sale upgrade kits get the heavy saw itsaalobetter
-- Stevo, work in tha city woodshop in the country
#8 posted 12-28-2012 05:08 AM
I looked at the pictures and it looks like they are both
Euro-style blade guides, but different designs. It’s
hard to speculate as to whether one guide design
will be better.
Practically, all blade guides work. Some saws are
very well made and you can position the guide-bar
post anywhere without resetting the guides on
the sides. Usually you’ll have to back off the
back bearing to change height settings more than
a few inches. Certainly the Euro style guides
tend to be quicker to adjust than the block
style guides. For the most precision I prefer
blocks but height changes tend to be a hassle
with a lot of saws if you want to set the blocks
super close.
Roller guides are fine too, but because they turn
the side of the blade can run against one or
the other and the setups are more forgiving
that way. Best practice though is to back off
the guides if they are set “tight”, change the
height, then readjust the guides “tight” at
the new height.
shelly_b
#9 posted 12-28-2012 05:16 AM
thanks:) if the cheaper on wasn’t on sale it wouldn’t be a question. But I think that even at $200 more I will probably go with the better one. It will be $1150 with shipping…I’m not sure if that is with or without tax. Do they ever give out coupons?
#10 posted 12-28-2012 05:16 AM
sorry shelly
in answer to your question
the trunnion is the semi-circular casting
the table attaches to
and lets it tilt
the G0513 (the cheaper one)
doesn’t even show it
so maybe they aren’t too proud of it
View gfadvm's profile
gfadvm
14940 posts in 2595 days
#11 posted 12-29-2012 03:15 AM
Shelly- I went through the same decision you are facing several years ago and I chose the 17” Extreme Series and have never regretted it. The cast iron trunions and wheels add a lot of mass and stability as well as being stronger and more durable. When I looked at the features I wanted: resaw fence, 12 resaw capacity, cast iron, and the biggest table I could get, the decision was made! I got very lucky and ordered mine when they had a free shipping deal going on this saw as well!
Straightbowed
#12 posted 12-29-2012 03:26 AM
Grizzly doesn’t charge out of state tax
JesseTutt
#13 posted 12-29-2012 04:39 AM
Others have reported that if you request a Grizzly catalog they will include a discount coupon. This may be for new customers only (???). Before I was a Grizzly customer I ordered the catalog but there was no coupon in it.
You could post and ask if anyone had a discount coupon they would share with you.
If you happen to live in one of the states where Grizzly has an office they do charge sales tax.
shelly_b
#14 posted 12-30-2012 06:52 PM
I’m in Ohio so I think I should be good on taxes. Thank you! I didn’t realize that! I love saving money:) I will keep an eye on my email and check my magazine for coupons. Thanks:) I think I will go with the bigger better one. My birthday is 1/8 so maybe I will wait on that money…then I wouldn’t need to spend very much at all!
View lwllms's profile
lwllms
555 posts in 3186 days
#15 posted 12-30-2012 07:25 PM
Shellly,
We have a 17” that came with ball bearing guides. The bearings were shielded bearings not sealed bearings. We use the saw commercially and use it a lot. I had to quickly replace the shielded bearings and I replaced them with sealed bearings thinking it would solve the short bearing life. It helped but on the second bearing replacement, I just bought the guides with ceramic discs. Even the discs require some maintenance but replacing 10 bearings every few months was expensive. The maintenance is just removing, cleaning, lubricating and reinstalling the discs.
Grizzly didn’t offer a cast iron trunion version when we bought our saw. Cast iron is better but we haven’t had any problem with the steel trunions. We do change the angle of the table frequently and the steel trunions are fine.
The one thing the saw doesn’t have is a break. I wish it did.
