| Forum topic by ZED | posted 149 days ago | 486 views | 1 time favorited | 12 replies | ![]() |
149 days ago |
Topic tags/keywords: question plane So I bought some hand planes and am in the process of refurbishing them. I have a Stanley #6 and #7 ! https://s3.amazonaws.com/ljimg/mfpv9vh.jpg! So I sandblastted them and got them cleaned up but now I need to paint them or oil/wax them any ideas? What type/brand of oil or wax. What blade to order etc. I need some suggestions and am totally open to be told what to do. -- A good craftsman is able to make it work with the tools he has, I still need more tools |
12 replies so far
#1 posted 149 days ago |
http://timetestedtools.wordpress.com/bench-plane-restore-the-dw-way/ -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#2 posted 149 days ago |
What is wrong with the blades in them now? -- Improvise.... Adapt...... Overcome! |
#3 posted 149 days ago |
Next time, reconsider the sand blasting part. My theory is that these planes (the good planes) work before so why change? -- I'll be a woodworker when I grow up. HHHOPKS |
#4 posted 149 days ago |
yeah so Don sand blastted his and I wantted to know what ype of wax to use as in what brand, he does not have that on his blog. I do like the electrolysis idea. And What the heck is japanning? -- A good craftsman is able to make it work with the tools he has, I still need more tools |
#5 posted 149 days ago |
Thank you for the help guys. Tri-H I was reading about the new steel being put out by Lee-Valey and thought I would try it. but your right the whole reason I got these was because they work and I want to learn how to care for them and keep them working. -- A good craftsman is able to make it work with the tools he has, I still need more tools |
#6 posted 149 days ago |
I use a mix of my own. Almost any kind of paste wax will work. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#7 posted 149 days ago |
Wax applied to the sole, during use? Anything will do. I melted down a candle, for example. Japanning is essentially an asphalt paint used on planes and other tools. The irons that came with your planes, unless totally used up, will do fine. Save that money for sharpening supplies, as that’s the gateway to hand tool use. -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#8 posted 149 days ago |
You can pick up some bees wax and mix it with turpentine. I’ve done the same with some old candles and that works. For a container I pick up small jar candles from the dollar store. The jars are great. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#9 posted 149 days ago |
I use the electr method to remove rust. -- I'll be a woodworker when I grow up. HHHOPKS |
#10 posted 148 days ago |
Personally I wouldn’t change the blade. The stock blade works like a charm. And i would dread to paint such a beautiful old tool. Depending on how thorough you are, the best result, in my opinion, comes if you remove the yoke and lateral adjuster. The yoke has a tiny pin you can knock out with a pin or a nail (dont knock it all the way, just enough to remove the yoke), and the lateral adjuster pin has to be filed flat on the back side of the frog, so you can tap out the pin. This would deter many, but I have done it on all my planes, and the pin is still sitting in there tightly enough. This gives you the oppourtunity to flatten the entire frog. Then I would flatten the sole of the plane (while the iron is in, but retracted) and finish the entire plane with a light coat of machine oil or such. If the blade is sharp that tool will work like a dream!!! Just my couple of cents -- David, Copenhagen, Denmark |
#11 posted 148 days ago |
Not bad for a first attempt Restoring tools can be addictive. -- Sawdust and shavings are therapeutic |
#12 posted 148 days ago |
A modern twist on japanning is possible. If you want more information on japanning, make sure to check out the comments in the blog, there are some good links found by other LJers. For starting out I would definitely recommend the Ford engine enamel that Don uses. Good old Johnson’s paste wax works well for protecting the metal. Welcome to the dark side of planes and restoring. There is no return. -- "The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself." -- Benjamin Franklin |
| Forum | Topics |
Woodworking Skill Share
8799 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15818 |
Hand Tools
2040 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6167 |
