Table Top Flat While I Work on the Rest?
Forum topic by Iffy posted 309 days ago 197 views 0 times favorited 5 replies Add to Favorites Watch
View Iffy's profile
Iffy
26 posts in 677 days
309 days ago
Topic tags/keywords: table top
Hey all,
I’m working on a solid walnut dining table and had a question about my planned order. Basically, I’m doing the table top first so that I can construct the base to the correct size (in case anything doesn’t go as planned with the table top). The table top is 8 or 9 walnut boards edge glued together to form a 40” wide surface.
So my question is, is the table top going to stay flat during the 2-3 weeks that it takes me to finish the base? Based on some reading I’ve done, it seems that once it’s on the base, being secured to the base will keep it flat. But what about before its on the base?
Or should I get sorta close on the base before I finish the table top to reduce the length of time the top sits without being attached to the base?
Thanks for any advice!
View Roper's profile
Roper
505 posts in 465 days
309 days ago
the longer you leave the top off the table the better chance you have of it warping on you. i would get the base pretty close then work on the top.
-- Roper - master of sawdust-
View Don Newton's profile
Don Newton
372 posts in 370 days
309 days ago
You can clamp a couple of cauls to the ends of the tabletop and set it aside.
-- Don, Pittsburgh
View John Ormsby's profile
John Ormsby
393 posts in 488 days
309 days ago
Don’s suggestion is a good one. I would also recommend you stand the top in a vertical position. Wood is more stable when stored vertically.Make sure that the edges are touching a wall or support equally so as to keep proper pressures on the board. It might twist if only one edge is touching.
-- Oldworld, Fair Oaks, Ca
View AkumAnubis's profile
AkumAnubis
16 posts in 566 days
309 days ago
You could also add bread-board ends to the top, which would add value and longevity to the final product as-well-as keep it flat while you make the base.
-- -...(insert inspiring phrase /quote)
View Iffy's profile
Iffy
309 days ago
Good tips. I really don’t like bread-board ends, so I’m going to pass on that. I think I’ll do a combination of the above suggestions. I’ll keep the table top disassembled until I finish the legs. Then once the legs are done I’ll do the table top and try the cauls method until I finish the aprons.
Bookmark And Share This Page
