Workbench base advice
Forum topic by LeChuck posted 12-27-2012 01:57 AM 919 views 0 times favorited 2 replies Add to Favorites Watch
View LeChuck's profile
LeChuck
424 posts in 3059 days
12-27-2012 01:57 AM
Hi folks,
I just bought a used workbench top from another woodworker. It’s made of some kind of fir, flat, heavy, and pretty solid and came with a heavy duty vice, and unfortunately I wouldn’t have the time to make one myself with all the projects I have, so this should work well for me for quite a while, at least until I get around to making the “dream” bench. Anyway, this workbench top was previously attached to the wall on a foldable mount and I need to build an actual base for it.
The difficulty is that even though the top of the bench is flat, the bottom is not. It was left as is, neither planed nor leveled (it’s a lamination).
Knowing that, any advice on building a base and attaching it to a workbench top with a non-flat or leveled underside? I am not sure yet if I want a trestle base or not, that part doesn’t matter that much to me.
Thanks,
David
-- David - Tucson, AZ
2 replies so far
View Dan Krager's profile
Dan Krager
4001 posts in 2231 days
#1 posted 12-27-2012 02:05 AM
That the whole underside isn’t leveled or parallel to top doesn’t matter. Decide on and build your base and level only the area(s) contacting the base. This can be done with a router or by hand. I would lean towards a router setup that works like the big slab leveling jigs, but I wouldn’t waste time trying to level the whole thing.
Post your progress on the Workbench smackdown topic.
http://lumberjocks.com/topics/31539
Good luck!
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
LeChuck
#2 posted 12-27-2012 02:09 AM
Thanks. I need to see how big the base will be and how much overhang I will leave on each side, especially the one with the vise (which unfortunately is not set into the apron to be flush). Leveling just those contact areas might work. I guess that means it would not be very practical to have a trestle base where the top stretchers contact the top over the whole width, but probably more of a 4 tenons approach. The top is about 2.5 inches thick…
I’ll post on that thread when I have something built, but it’s cheating a bit if I haven’t made the top myself :) Someday…
