| Forum topic by MackTheSaw | posted 309 days ago | 531 views | 0 times favorited | 8 replies | ![]() |
309 days ago |
Hi all, I’ve had a wooden-bodied hand plane for over 10 years that I’ve never really used. I got it from the sculpture department in my university because they had six of them that had never really worked too well. Here’s a description: It looks to me like beech, with a lighter-colored wood joined on the bottom for the sole. It’s 8 3/4 long, 2 1/2 wide. Iron is 1 7/8 wide, and quite thick, tapering from almost 3/16 at leading edge to 1/8 at the back. Looks like iron has a laminated harder steel for the cutting edge, like a japanese chisel. It’s marked “ORIGINAL STEINER 1859” behind the tote, “48” on the back, above the adjustment button, and “48 m/m CHROME VANADIUM” on the iron. It’s clearly not very old, maybe 20 years. It looks almost identical to the Ulmia scrub plane in the following eBay listing, except the angle of the frog and iron are much more inclined. Ulmia plane on eBay for comparison It seems like, when the chip breaker is attached 1/32 from the end of the iron, and the iron is projecting just a bit from the mouth, there’s almost no room left for shavings to pass through the mouth. The mouth is tight. I’m guessing this plane is a smoothing plane, and so should not have much space in the mouth, but I can’t seem to cut anything without clogging it up. Can anyone help me make a useful tool out of this doorstop? |
