Planer Purchase Dilemma
Forum topic by flyboy posted 143 days ago 653 views 0 times favorited 13 replies Add to Favorites Watch
View flyboy's profile
flyboy
91 posts in 1440 days
143 days ago
Hello everyone. I am hoping to get some advice on a planer purchase. I have a chance to get either a Grizzly 1021 15” planer or a Parks model 97 -12” planer. Both are in very good shape and taken care of. They both agreed to the same
tool trade plus cash. I have heard you can still get parts for the Parks and I know Grizzly is the same. I guess I would like to hear from past experience of previous owners as to the pros and cons. I hope that everyone has a great Christmas and Holiday. Also everyone please remember our men and women in uniform and keep them in our thoughts. Thanks, Flyboy
-- 160th S.O.A.R
13 replies so far
View Dan Krager's profile
Dan Krager
710 posts in 399 days
#1 posted 143 days ago
First and foremost, thank you for YOUR service to our country.
IMHO, you can’t go wrong with either machine for light to medium duty. Either one will occasionally do some heavy duty planing, but I just don’t like to push machines real hard.
I would verify availability of parts before deciding on the Parks. It’s a classic machine but it doesn’t offer some of the modern amenities: think spiral cutter head, variable speed feed etc.
Neither machine will produce a finish comparable to the 90+ CPI of an RBI, Belsaw, Woodmaster, or PorterCable unless you put a spiral head in the Grizzly. Maybe that’s not so important to you?
Merry Christmas!
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com
flyboy
#2 posted 143 days ago
Hi Dan. I appreciate the kind words. Parts availibility is the big thing sticking in my head. I spoke with Grizzly and theysaid that even though the 1021 is slightly older that parts are no problem. Plus the fact of 15” vs 12” even if I don’t always need the extra width. The only reason I am doing this is my Dewalt 734 is on it’s last leg. Plus I like to buy rough sawn lumber which I feel a larger planer can handle better. So far I am leaning towards the Grizzly. What also meant a lot to me was the fact that the Grizzly rep spent a lot of time answering questions like I was spending big bucks on mew equipment and that meant a lot to me. Flyboy
-- 160th S.O.A.R
View Straightbowed's profile
Straightbowed
574 posts in 463 days
#3 posted 143 days ago
i WOULD go with bigger heavier GRIZZ
-- Stevo, work in tha city woodshop in the country
View exelectrician's profile
exelectrician
1004 posts in 592 days
#4 posted 143 days ago
Do yourself a favour and at least look at a DeWalt new at the Home Depot on clearance now. Easily the most well regarded planer out there. You simply do not need heavy cast iron to do what modern tech can do.
-- Love thy neighbour as thyself
flyboy
#5 posted 142 days ago
I will admit that my Dewalt did not owe me anything when it gave up the ghost. I ran a lot of boards through it over the years. My big thing is rough sawn lumber which I found myself going to the local mill to get planed. I feel a bigger machine will give me many years of running this kind of lumber. I have to call both guys back today and let them know which one I want. There is worse decisions to have to make in life than this. Flyboy
-- 160th S.O.A.R
12047 posts in 1506 days
#6 posted 142 days ago
so many imply that a wider planer is better
and it is nice for the occasional wide board
to me it’s true value
is in having spots for different phases of planing
like i run all my edges first thru one place
then flip over and run again
flat pieces can have a spot
where there are no nicks
new rough lumber can go thru nicks
as they will be finished or sanded later
rather than using fresh spots in it for every piece
and changing knives more often
i can get more work from it
by being selective about where i feed the boards
runswithscissors
608 posts in 190 days
#7 posted 142 days ago
The benchtop planers use rubber rollers, which aren’t so good on rough cut boards. Both the Parks and Grizzly use a steel segmented feed roller, which will work much better. Plus, the Grizzly has a 220 v. induction motor, which is way superior to the universal motor found on the Dewalt. Do you know what motor the Parks has? I’ve seen a Parks planer with a huge 110 v. induction motor, rated at 24 amps. That would require a 30 amp. circuit. Don’t ever seem to see motors like that any more, which is just as well. Some of those motors are convertible to 220 v. operation, which is preferable if you can do it.
flyboy
#8 posted 142 days ago
The point of wider isn’t always better is true. I can only think of two times that I actually ran boards that size. They tell me I can get parts for the Parks out of Kentucky but I have not verified that yet. Hi runswithscissors. I just found out that the Parks has a 3hp Leeson on it which is only a year old. It helps that he has the invoice. I know the Leeson on my Performax sander has been bullet proof. Now I probably jinxed my drum sander by saying that. My wife and I are sitting around talking about this tonight and she comes downstairs with a Grizzly catalog and asks me why I just don’t order a new one from them. Like my head didn’t hurt enough already. Flyboy
-- 160th S.O.A.R
Dan Krager
#9 posted 142 days ago
Dan Krager
#10 posted 142 days ago
...others are having similar struggles. It’s a big investment and worth thinking through, but not stressing out over it.
http://www.sawmillcreek.org/showthread.php?89560-PM-vs-Grizz-15-quot-Helical-planers
One small point. No one is making helical or spiral cutterheads for the the Parks. Grizzly keeps that option open, but in either case you might be money ahead to trade out the machine later if you need to upgrade. It’s just a machine…
DanK
Dan Krager
#11 posted 142 days ago
flyboy
#12 posted 142 days ago
Hi Dan. I appreciate the links. It does make good sense to think down the road that I could upgrade to a spiral cutterhead. I told the wife I appreciate the gesture but laying out for a brand new machine might be down the road. I have 8 more years until my second retirement and maybe I could make it my gift to myself. Flyboy
-- 160th S.O.A.R
View MedicKen's profile
MedicKen
1560 posts in 1627 days
#13 posted 141 days ago
PARKS!!!!
