Wood Stove Installation
Forum topic by Tyler posted 12-24-2012 11:11 PM 3164 views 1 time favorited 10 replies Add to Favorites Watch
View Tyler's profile
Tyler
52 posts in 2253 days
12-24-2012 11:11 PM
Topic tags/keywords: wood stove shop heat
So i finally finished up with my wood stove install. It was nearly as tough as i thought or expensive either. I started with finding the right area for my shop wich i was goin to have it catty cornered but with the rafter beams it wouldnt work going threw the ceiling. I didnt want to go through the side just funny about 2 90 degree turns. so i wreslted with putting the single wall pipe all togetheand damperr, i think it was maybe 5 pieces. i used 3 screws to attach the pipes. i then sealed the joints with high temp caulk. after the caulk dried i cut a 6 inch hole and cut slits in it so i could flare it out for proper air space so it wouldnt be metal on metal burning. i added a few trim collars on the bottom and added to the inside of the collar some high temp fire block. the foam type. i secure the collar wich fit tighte with teh pipe and finish with high temp caulking.. I added the smoke stack so that it was 3ft above the roof line and anded a cheap guard for it. i added another collar, foam fire block and caulking with a thick layer of roofing cement so the water would run off into the drain system. after the first burn it was perfect. just a lil smell from new metal.
-- You can get alot further with a kind word and a hand gun, than just a kind word alone
10 replies so far
runswithscissors
2928 posts in 2266 days
#1 posted 12-25-2012 12:16 AM
Nice looking install. Box type stoves are no longer legal in WA state (and I think OR and CA as well). I’m using an old trash burner. What I like is that I can keep the piles of offcuts and other scrap under control. Raises the temp in my uninsulated shop 2 or 3 degrees, too.
View RogerM's profile
RogerM
799 posts in 2640 days
#2 posted 12-25-2012 12:48 AM
Nice installation Tyler. I believe that you will be more than pleased with it’s performance. I put in a LOPI high efficiency wood burner with double walled pipe and insulated pipe (wooden shop structure) over 5 years ago and love it. Hope you are as satisfied with yours as I am with mine.
-- Roger M, Aiken, SC
Tyler
#3 posted 12-25-2012 01:59 AM
Oh i love it….i was a lil nervous doing it but im glad i did…just a lil reminder take the stickers off the pipe before you get a good burn on it… lol…it was around 45 the other night and it was a nice 65 in the shop…:)
View kizerpea's profile
kizerpea
775 posts in 2608 days
#4 posted 12-25-2012 04:24 AM
looks good…now get a cheap box fan to sit behind an it will b on…
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View redryder's profile
redryder
2393 posts in 3343 days
#5 posted 12-25-2012 08:08 AM
Your install looks great.
I have two ceiling fans in my shop to circulate the heat down. The wood stove keeps it as warm as I want it.
Not sure why someone would say Box type stoves are no longer legal in WA state. They are sold everywhere............
-- mike...............
Gerald Thompson
1143 posts in 2475 days
#6 posted 12-25-2012 05:52 PM
Keep an eye on the single wall stove pipe. The effluent cools rapidly on a long run and condeses in the pipe. This stuff will eat through the pipe and can present fire and CO hazards.
This comes from personal experience.
-- Jerry
Tyler
#7 posted 12-26-2012 01:13 AM
Thanks for the comments and tips to look for
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#8 posted 12-26-2012 03:49 AM
Looks good. Now get a chimney brush and keep your stovepipe clean to prevent “chimney fires”. They are no joke!
View BentheViking's profile
BentheViking
1782 posts in 2805 days
#9 posted 12-26-2012 03:57 AM
gonna be toasty
-- It's made of wood. Real sturdy.--Chubbs Peterson
redryder
#10 posted 12-26-2012 06:24 AM
I agree with Jerry. I would have gone with double wall pipe but what is done is done.
Burning dry wood and burning it hot will keep the creosote down.
I like the fact that wood stoves take the moisture out of the air and your wood stock quickly.
You know, that whole “wait a year per inch thing”. Who’s got the patience for that…......................
