cutting sequence
Forum topic by trz posted 12-24-2012 08:26 PM 1153 views 1 time favorited 7 replies Add to Favorites Watch
View trz's profile
trz
90 posts in 2724 days
12-24-2012 08:26 PM
building a small box (9×6x5) . what would be the best cutting sequence on a RIGHT tilt table saw to get a continuous grain look for the box? I’ve looked at the video on youtube with the sliding miter saw but just can’t seem to wrap my head aroung how to do that on the right tilt table saw.
7 replies so far
View Grandpa's profile
Grandpa
3261 posts in 2914 days
#1 posted 12-24-2012 08:50 PM
I am not sure about the question you are asking. If you are building a closed box and want to saw it open on a table saw the only thing to remember is to keept the same side agains the fence on every cut. Remember to check everything and make sure the blade is exactly 90 deg etc.
View trz's profile
trz
#2 posted 12-24-2012 09:50 PM
I’ts more of a question as to how to get the continuous grain and still get two sets of equal lenght sides. not able to use stop blocks it wouldn’t seem.
View gfadvm's profile
gfadvm
14940 posts in 2928 days
#3 posted 12-25-2012 03:13 AM
You can and should use stop blocks on your miter gauge fence extension. Cut miters on both ends of your first piece, Then cut the miters on subsequent pieces keeping the same side face up for every cut. Flat cut all 4 sides about 1 1/2 ” longer than the final sides and number them sequentially before you cut any miters. Hope this didn’t confuse you more. It’s easier to do than to describe! You will wind up with the grain wrapped around 3 sides. Haven’t found a way to get it wrapped around that fourth corner (put in on the back).
View trz's profile
trz
#4 posted 12-25-2012 04:10 AM
Gfadvm I think that helps. I was trying to figure out how to do it cutting the miters as i go, but doing it your waay by cutting all pieces square first i think will make it easier. Ya, i realize the wrap is only 3 cornered.
thanx
gfadvm
#5 posted 12-25-2012 04:29 AM
Great plan Jonathan! That will do all 4 corners. You da man!
View trz's profile
trz
#6 posted 12-29-2012 12:50 AM
next step, i want to round over the top and mitered sides of the box. will it matter which i do first?
117417 posts in 3815 days
#7 posted 12-29-2012 12:57 AM
If your not going to have a rabbit on the top then round over before you miter .
