Drilling large hole over small hole or vice-versa
Forum topic by niki posted 05-21-2007 11:25 PM 3248 views 1 time favorited 4 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 3986 days
05-21-2007 11:25 PM
Good day
Usually, when we want to drill small hole and large hole at the same center, we start with the large hole and using the center dot, we drill the small hole.
But, I like to prepare a bunch of “wheels”, cut with the “Hole saw” that has 1/4” drill, to use as knobs for jigs.
I don’t know if the small hole will be 1/4”, maybe I shall have to enlarge it to 5/16” or 3/8” and also, I don’t know what will be the diameter of the large hole for the bolt head, washer or T-nut.
Another problem is that, sometimes one drill is longer that the other and I have to change the table height that is very difficult to return to the same “center” position on my cheap Drill stand.
So, that’s what I did…
Regards
niki
35099 posts in 4307 days
#1 posted 05-22-2007 01:25 AM
Great trick Niki.
View David's profile
David
1970 posts in 4045 days
#2 posted 05-22-2007 08:25 AM
Niki -
I just love your engineering skills! You always have very interesting posts. This is a neat trick to keep in mind for future projects.
View niki's profile
niki
#3 posted 05-22-2007 09:29 AM
Thank you
David
“Engineering skills”??? no way, just necessity.
BTW, I downloaded your “Workshop” (for 15 min) just to get the nasty massage that “Can not play this file”.
Well, You cannot expect so much from Windows 98…
niki
View WayneC's profile
WayneC
13751 posts in 4004 days
#4 posted 05-23-2007 08:10 AM
Hmmmm. How to adapt this to my new (used) radial drill press.
Thanks for sharing.
