What is 3HP
Forum topic by agallant posted 12-24-2012 02:05 AM 3268 views 2 times favorited 46 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2763 days
12-24-2012 02:05 AM
What exactly does 3HP mean? I really doubt my 3HP shop vac motor could replace the motor on my 3HP unisaw. So what exactly is 3HP then?
46 replies so far
View ShaneA's profile
ShaneA
6882 posts in 2475 days
#1 posted 12-24-2012 02:10 AM
The shop vac is 3 peak hp…whatever that means. Motors should max out in the 1.75hp range with 110 power. The inductions motors should be able to maintain a constant hp output.
9775 posts in 3524 days
#2 posted 12-24-2012 02:13 AM
With induction motors (like on you unisaw) horsepower
is generally a useful and accurate rating of what the
motor can do. With universal (brush type) motors,
it is marketing hyperbole.
View lab7654's profile
lab7654
266 posts in 2123 days
#3 posted 12-24-2012 02:27 AM
That’s something that bugs me too. Where do the companies get these numbers? I’ve seen shop vacs ranging to 6.5HP…
-- Tristin King -- When in doubt, sand it.
View Dallas's profile
Dallas
3599 posts in 2363 days
#4 posted 12-24-2012 02:27 AM
1 HP = 746 watts.
It doesn’t matter if it’s 120V or 240V or 480V. A watt is a watt is a watt.
Watts are derived from this formula: V x A = P (expressed in watts).
When small motor manufacturers post, “3HP”, “5HP”, “6HP”, etc. they are referring to what is called ‘LRA’ or “locked rotor amps” which is the point at which the the armature in the motor actually can no longer turn. They use some sophisticated breakers and software to make sure they are giving an accurate description, (by Law), but it’s not really a true reading.
When you remove the air flow from a vacuum pump like a shop vac, there is actually less stress on the motor.
To put more load on it, you would have to thicken the atmosphere being taken in.
An induction motor is also tested the same way, except they are working with better components and testing for actual LRA by actually putting a physical load on the motor, not a theoretical software induced load.
Good Luck!
View Moron's profile
Moron
5032 posts in 3770 days
#5 posted 12-24-2012 03:02 AM
3 HP
3 horse power
the original average law of what a horse can do ?
search “you tube” on what 1 horse can wreak havoc on
and imagine 3 of them
beautiful animals
to be respected
versus say a cat power CT
View MJCD's profile
MJCD
515 posts in 2247 days
#6 posted 12-24-2012 03:44 AM
Welcome to Marketing’s wacky world of ‘puffery’ – the legal over-statement of capabilities; as in – that car has the interior space of the Astrodome.
Having said this, the previous posts get you to the facts – a HP is 746 watts; Amps * Volts = Watts: even with this, we’re assuming 100% motor efficiency, and that the motor will still survive at some rated level – router manufacturers have been know to use Bushings rather than Bearings; less than stellar cooper for their armature windings; and all sorts of less-than-forthright manufacturing and marketing terms and conditions.
The only advise is to not trust anything.
MJCD
-- Lead By Example; Make a Difference
View Ted's profile
Ted
2838 posts in 2087 days
#7 posted 12-24-2012 03:55 AM
Dallas, thanks for cluing us in… well, me anyway. I favorited this topic just so I can come back and read your formulas a few more times so they’ll sink in.
Moron, I like your formula too… not as scientific but horses are way cool. Who killed the cat?
-- You can collect dust or you can make dust. I choose to make it.
View knotscott's profile
knotscott
7822 posts in 3252 days
#8 posted 12-24-2012 04:24 AM
”I favorited this topic just so I can come back and read your formulas a few more times so they’ll sink in.”
Ted, as MJCD points out, you need to add a loss factor into that equation in order for it to result in anything close to a realistic HP rating…..most decent motors of the types we use in woodworking operate at only 60-70% efficiency, so multiply the result of Dallas’ formula by a factor of roughly 0.65, and you’ll have something closer to the real world usable HP. The actual efficiency could even be less.
If we assume a nominal 15 amps for a typical 1.5hp induction motor running on 120v. 15 amps x 120v = 1800 watts. Divide that by 746 to get a pure theoretical 2.41hp. Then multiply that times 0.65 for a number approaching the realistic ratiing….1.57hp in this case.
A good common sense rule of thumb….if it plugs into a standard 120v residential outlet, it’s not over 2hp.
View Straightbowed's profile
Straightbowed
717 posts in 2174 days
#9 posted 12-24-2012 04:29 AM
who said 2+2 =4 could be 7
-- Stevo, work in tha city woodshop in the country
runswithscissors
2605 posts in 1901 days
#10 posted 12-24-2012 06:07 AM
Not only has horsepower become an almost meaningless term (as used in marketing), how about “professional” and “industrial”? Do those words have any real meaning nowadays?
TopamaxSurvivor
18163 posts in 3552 days
#11 posted 12-24-2012 06:23 AM
1 HP = 746 watts in DC motors in a perfect world. For AC motors, 1 hp will be closer to 1400 watts or 11.5 amps. That is about max on your typical 15 amp garage circut at 120 volts.
View EdwardR's profile
EdwardR
66 posts in 2130 days
#12 posted 12-24-2012 06:26 AM
HP is meaningless ( well almost) lol. The difference is TORQUE. you can have two motors both 3hp the one with what i call empty HP will be weaker. The more powerful 3hp motor with GUTS will also be bigger and heavier and yes more expensive. This can be acheived also with gearing and pully size. Amps = power
A way to explain is take these little bumblebee in a can cars these kids drive with outrages HP in a 4 cylinder. they have to wind the living crap out of it to get it to move and any slight traction loss or bog will kill it.
TopamaxSurvivor
#13 posted 12-24-2012 06:58 AM
Hp is meaningless on consumer tools such as table saws and shop vacs. It is still the method of sizing motor circuits in the National Electrical Code. Just taking the first 1 hp motor that popped up on goggle search , notice the full load amps (FLA) are 13.4 on 115 volts o0 6.7 on 230 volts. Forget claimed HP, look at FLA on the motor name plate.
View Ted's profile
Ted
#14 posted 12-24-2012 07:21 AM
I had a 3-1/4 HP Porter Cable router some time back and that thing would drive recessed panel bits with no problem. I now have a 3-1/4 HP Craftsman router that no way will it do the same in a single pass.. it takes 2 passes minimum.
knotscott
#15 posted 12-24-2012 11:55 AM
So, to answer your question…..”3hp” is roughly 3 times more BS than 1hp…...;-)
showing 1 through 15 of 46 replies
