Some Designs you just need to Sleep on - What do you think?
Forum topic by Mike posted 145 days ago 663 views 0 times favorited 16 replies Add to Favorites Watch
View Mike's profile
Mike
259 posts in 852 days
145 days ago
Topic tags/keywords: maple bed frame bedroom sleep
So after many months, I decided to go ahead and start designing and building a new bed frame. Based on the design on the cover of the the Feb. 2013 issue of Fine Woodworking this is what I felt would be a good starting point. Not wanting to jump right in and start building from the plans inside, I CADed the project first (using Solidworks). While the plans inside state that they are for a queen sized mattress, the frame was small for the one that I own. I did not include any of the bolts or hardware that I may need to use in the renderings. Since this is going to be one of the larger pieces that I build, I’d love to hear any suggestions or tips that you can come up with.
Thanks!
Mike
Click here for larger images!
-- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com
16 replies so far
View MNgary's profile
MNgary
210 posts in 582 days
#1 posted 145 days ago
You’re off and running to a great design, Mike. Are you thinking of adding some interest to the inside of the headboard’s center panel (and outside of footboard’s) by either cutting boards to arrange a vee pattern or by using an intriguing veneer?
You may want to add pillows and a bedspread to your CAD to see what it will look like in the bedroom. Doing so may lead you to consider making the legs as deep as they are wide with, perhaps, tapers on two sides below the rails.
-- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse
View Mike's profile
Mike
#2 posted 145 days ago
MNgary thank you for the input!
I am thinking about adding some flare to the design but really haven’t come up with anything in particular. I am playing around with maybe a color stain, making the panels in a different color, or just painting the bed.
I am seriously considering making the posts thicker for more support with the tenons and mortises. Perhaps reduce the stock size once it gets above the bed rail, but I’m not sure.
View Monte Pittman's profile
Monte Pittman
7029 posts in 503 days
#3 posted 145 days ago
Looks like you have a good plan. Well thought out.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
Craftsman on the lake
2018 posts in 1602 days
#4 posted 145 days ago
How about different woods? Maybe a darker wood for center panels or the vertical slats. So, wood combos like maple/walnut, or maple/oak
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View Mike's profile
Mike
#5 posted 145 days ago
Craftsman thank you for the input. Did you mean something like this?
View AandCstyle's profile
AandCstyle
635 posts in 422 days
#6 posted 145 days ago
Basically, I like your latest rendering. I would consider making it more G&G style, by adding cloud lifts to the top of the head and foot boards. I guess that I think the design is a little plain, even with the color variation, and would use the cloud lifts to create additional visual interest. FWIW
-- Art
View Mike's profile
Mike
#7 posted 145 days ago
Art,
Thank you for the input. I’m not familiar with either G & G style nor cloud lifts. Do you have an example or two?
Mike
View pintodeluxe's profile
pintodeluxe
1731 posts in 978 days
#8 posted 145 days ago
I like the wide splat, and pairs of slats. That makes good use of the negative shape between spindles. I wonder if a cap on the headboard would add some depth, and an interesting shadowline?
View Mike's profile
Mike
#9 posted 145 days ago
I just played around with making a decal of a fish on the head board. Let me know how it looks.
Here is a larger version
TopamaxSurvivor
13192 posts in 1841 days
#10 posted 145 days ago
I think a darker center board would look better than the dark slats.
View TCCcabinetmaker's profile
TCCcabinetmaker
735 posts in 520 days
#11 posted 144 days ago
the center is going to be a panel, you could make it with a couple of different types of wood to throw in some contrast, or go with what you got for a more traditional style.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View knockknock's profile
knockknock
47 posts in 338 days
#12 posted 144 days ago
Thinking more along the lines of construction. Instead of mitering the top rail to the leg, I would make it a cap piece. With the mortise in the rail and the tenon on the leg (maybe haunched to the outside edge), or use a bridle joint. For assembly, you would insert the lower rails and panel into the legs, then your spindles and upper panel and finally the top rail.
View BHolcombe's profile
BHolcombe
40 posts in 240 days
#13 posted 138 days ago
I like your prior design better, I think the reality of it in wood will be all the ‘interest’ needed. I would make the center panels in 1/4 sawn veneer over ply.
I might make the legs and cap rails out of heavier stock and also make them a bit narrower.
AandCstyle
#14 posted 137 days ago
Mike, I apologize for not replying to you sooner. We went away for Christmas and I am just getting caught up. Greene & Greene were great architects that designed houses, furniture, etc. Their work is very often characterized by cloud lifts, which are basically a couple little step ups along the sides. Here is a picture that illustrates what I am attempting to describe. I hope you like it.
-- Art
View MrRon's profile
MrRon
1571 posts in 1408 days
#15 posted 137 days ago
I’m personally against foot boards. They make it harder to make up the bed and my feet would always touch the foot board preventing me from straight legging.
