Another Jointer Help Question
Forum topic by cutworm posted 12-23-2012 09:37 PM 1205 views 0 times favorited 9 replies Add to Favorites Watch
View cutworm's profile
cutworm
1075 posts in 2817 days
12-23-2012 09:37 PM
I’ve had my jointer a couple of weeks now and I am in the learning and exploring phase of my ownership. I have the knives set to within about .01 to .02mm of each other and IB to OB variance as well. I ran test cuts and have a question. I made 6 passes on a 4” wide board in the same direction and orientation and measure a thickness difference on the board of about the thickness of one of the lines on my scale of my vernier caliper. I’d guess at about just under 1/64th”. I have no idea as to what is acceptable or unacceptable on a jointer. I can say that adjustments are pretty crude on the knives made by 2 jack screws on each knife. Please share any methods or info on setting the knives correctly.
Thanks,
Steve
-- Steve - "Never Give Up"
9 replies so far
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#1 posted 12-23-2012 10:17 PM
Is the thickness difference from side to side, or from one end to the other?
Crooked blades could create a side to side taper. Jointer beds not exactly coplaner will result in a long taper from one end to the other. Jointer beds must be within .002” of coplaner to avoid cutting tapers.
cutworm
#2 posted 12-23-2012 11:07 PM
Sorry. Side to side.
View teejk's profile
teejk
1215 posts in 2708 days
#3 posted 12-23-2012 11:21 PM
hard to tell but you are explaining a planing operation vs. a jointing operation? if so one or more of your knives are high or low.
goof with it you want but I personally would marry a jointer that would get under 1/64th after 6 passes running in the same direction (that is to say that I think you have it tuned about as best as you will ever have it tuned…mess with it and you’ll be posting back about why the variance is 1/32nd).
cutworm
#4 posted 12-23-2012 11:32 PM
Tee,
I guess I was planing. I did repeat passes to hopefully compound the error. My cup is nearly empty when it comes to jointers. The error seems ok to me but I really don’t know for sure. My total knowledge comes from a video or 2 on youtube. It would be nice to have a sure fired method. I spent several hours setting the knives with a dial indicator. What a pain. Thanks for the info. I sorta thought I may need to quit while I have it pretty close. I thought I might try to alternate directions and see what happens. New stuff to me.
Thanks,
Steve
teejk
#5 posted 12-24-2012 02:08 AM
steve…less than 1/64th after that many passes…I say you have done a great job. It is indeed wood (even if absolutely perfect, you would make it less so simply in sanding).
View Straightbowed's profile
Straightbowed
717 posts in 2321 days
#6 posted 12-24-2012 04:37 AM
give up on perfection start building worry more about finishing thats the whole key to woodworking just sayin just kiddin merry xmas
-- Stevo, work in tha city woodshop in the country
10476 posts in 3671 days
#7 posted 12-24-2012 05:35 AM
Flatten one side, then make that side parallel on the planer.
If your planer is off from side to side, fix that. The jointer,
being a hand-fed machine, is subject to operator error.
cutworm
#8 posted 12-24-2012 03:56 PM
Great! Thanks for the advice. I’ll leave well enough alone. I dread the day I need to replace knives. 10-4 on the operator error. That’s my middle name. Oops!
View Fuzzy's profile
Fuzzy
298 posts in 4012 days
#9 posted 12-24-2012 10:42 PM
” Jointer beds not exactly coplaner will result in a long taper from one end to the other. Jointer beds must be within .002” of coplaner to avoid cutting tapers.”
I BELIEVE you mean PARALLEL tables … not COPLANAR …
COPLANAR tables will give you a large, sweeping curve with a big snipe at the trailing end.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
