Linseed oil--preserving lighter/darker shades in wood
Forum topic by Jumpinjack posted 12-23-2012 02:08 PM 2280 views 0 times favorited 7 replies Add to Favorites Watch
View Jumpinjack's profile
Jumpinjack
1 post in 1851 days
12-23-2012 02:08 PM
Topic tags/keywords: finishing arts and crafts
Hi,
I’m finishing a small wood project in sapele that has some carved/chiselled elements, leaving lighter shades in the wood that form a pattern.
I’m finishing the wood in boiled linseed oil, which is giving it a really nice, deep colouring, however I’m worried that when I get to the patterned parts on the front it’ll just create a blanket shade of reddish-brown and the pattern will be lost.
Is there a way that I can preserve the lighter parts?
Thank you for ANY help you can give!
7 replies so far
View paratrooper34's profile
paratrooper34
915 posts in 2822 days
#1 posted 12-23-2012 02:15 PM
Jumpinjack, although there are some that are going to tell you that BLO will ruin your project, I think it makes a wonderful finish.
Is there a way that you can make a test piece and replicate the pattern so you can test what effect the BLO will have? That would be the best suggestion I could give you.
Good Luck!
-- Mike
View Arminius's profile
Arminius
304 posts in 3674 days
#2 posted 12-23-2012 02:36 PM
Thin the oil going on those parts a little, and you should see less of a color shift – but definitely try a test pattern first if you can.
16272 posts in 4089 days
#3 posted 12-23-2012 02:56 PM
Any oil will darken wood to some extent, but the color change should be fairly uniform, so you will still maintain a good contrast between the light and dark areas.
As mentioned, testing would be good if possible.
View Stargazer's profile
Stargazer
49 posts in 2810 days
#4 posted 12-24-2012 03:23 AM
^This^
Rick
View Clint Searl's profile
Clint Searl
1533 posts in 2231 days
#5 posted 12-25-2012 10:31 PM
Your first mistake was using BLO (which is only good for starting fires); your second mistake is thinking of using more BLO. It’ll just make things muddy and darker. The effect you seek can be achieved by spraying a matt or low luster lacquer. Rattle can type will work just fine.
View lj61673's profile
lj61673
261 posts in 2270 days
#6 posted 12-25-2012 10:55 PM
Disregard Clint’s post, his ignorance about blo is only exceeded by his willingness to show it. BLO does NOT muddy anything though it will slightly darken while it enhances the grain. It has been used by fine furniture makers and expert woodworkers for many decades. Research it for yourself , educate YOURSELF and don’t rely on some Internet nitwit to guide you.
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#7 posted 12-25-2012 11:19 PM
Oil finish will most likely darken the end grain areas of a carved pattern more than the other areas. In that way it can actually accent the carved areas. The question is, if it appeals to you? Only experimentation and experience will tell you.
-- Bondo Gaposis
