My first walnut bowl.
« back to Woodturning forum
Forum topic by RussellAP posted 149 days ago 476 views 0 times favorited 6 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 455 days
149 days ago
This is five boards glued up. I glued a couple small boards on so I could attach it to my lathe but the screws I used were too long and I brain farted and now there are holes in the bowl.
I figured it was a job for some epoxy and steel filings.
It’s for an old friend who want’s to give it to her sister, also an old friend. So I hope she likes it. I’m only charging her for the wood that I have in it. I need some practice on these bowls. This one broke off the glue mounting midway through the hollowing process and I had to reglue it which means re-turning it. It took most of the day, and three days prior just in gluing up.
In other words, a lot of work goes into one of these.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View robert triplett's profile
robert triplett
1304 posts in 1273 days
#1 posted 149 days ago
It is a lot easier, and often cheaper, to use a chunk of wood instead of a glue up. But we can’t always find that big chunk! Overall a nice bit of work. A lot of learning going on I bet! I ‘once’ did the same mistakes with the screws.
-- Robert, so much inspiration here, and so little time!
View Alexander's profile
Alexander
185 posts in 1279 days
#2 posted 149 days ago
very nice color. to fill the holes try 5 second glue and coffee grounds. the grounds will san out and look like knots.
-- John at Sugarloft Mountain........Don't argue with an idiot; people watching may not be able to tell the difference.
View Steve Peterson's profile
Steve Peterson
180 posts in 1250 days
#3 posted 148 days ago
That’s a good looking first bowl. I like the color and figure in the wood. They should get easier and better looking as you do more.
It might help to get a power sanding attachment with some 80 grit paper. This would help to reduce the tear out. It sure cuts down on the sanding time.
-- Steve
87120 posts in 1745 days
#4 posted 148 days ago
The first of many to come.
View hhhopks's profile
hhhopks
546 posts in 545 days
#5 posted 148 days ago
Next bowl, a blog is in order.
-- I'll be a woodworker when I grow up. HHHOPKS
View Roger's profile
Roger
9191 posts in 972 days
#6 posted 148 days ago
A really nice Walnut bowl.
